I recently switched to Ubuntu Budgie 23.04 for a while now, I came across an issue, the top panel disappeared for a while(like 2-3 secs) then reappeared, after that sometime nothing happens, but sometime it shows a window that said “Oh no! Something has gone wrong.” with a logout button. Any ideas how to fix this?
Hi and welcome!
That observation is typical of an applet crashing.
Have a look in /var/crash … do a
ls -l /var/crash
What are the recent files there?
Also run
journalctl -ae | grep -i budgie
What is the output?
Hi there, thanks for responding!
Here’s the output
(base) aung8430@aung8430:~$ ls -l /var/crash
total 153188
-rw-r----- 1 aung8430 whoopsie 64720673 Aug 13 10:59 _opt_microsoft_msedge_msedge.1000.crash
-rw-r--r-- 1 aung8430 whoopsie 0 Aug 13 10:59 _opt_microsoft_msedge_msedge.1000.upload
-rw------- 1 whoopsie whoopsie 37 Aug 13 10:59 _opt_microsoft_msedge_msedge.1000.uploaded
-rw-r----- 1 aung8430 whoopsie 14002435 Aug 13 10:59 _usr_bin_budgie-panel.1000.crash
-rw-r--r-- 1 aung8430 whoopsie 0 Aug 13 10:59 _usr_bin_budgie-panel.1000.upload
-rw------- 1 whoopsie whoopsie 37 Aug 13 10:59 _usr_bin_budgie-panel.1000.uploaded
-rw-r----- 1 aung8430 whoopsie 48757942 Aug 13 12:11 _usr_share_code_code.1000.crash
-rw-r--r-- 1 aung8430 whoopsie 0 Aug 13 12:11 _usr_share_code_code.1000.upload
-rw------- 1 whoopsie whoopsie 37 Aug 13 12:11 _usr_share_code_code.1000.uploaded
-rw-r----- 1 aung8430 whoopsie 29356607 Aug 13 10:59 _usr_share_discord_Discord.1000.crash
-rw-r--r-- 1 aung8430 whoopsie 0 Aug 13 10:59 _usr_share_discord_Discord.1000.upload
-rw------- 1 whoopsie whoopsie 37 Aug 13 10:59 _usr_share_discord_Discord.1000.uploaded
(base) aung8430@aung8430:~$ journalctl -ae | grep -i budgie
Aug 13 18:36:48 aung8430 systemd[1]: Mounting snap-ubuntu\x2dbudgie\x2dwelcome-447.mount - Mount unit for ubuntu-budgie-welcome, revision 447...
Aug 13 18:36:48 aung8430 systemd[1]: Mounting snap-ubuntu\x2dbudgie\x2dwelcome-465.mount - Mount unit for ubuntu-budgie-welcome, revision 465...
Aug 13 18:36:48 aung8430 systemd[1]: Mounted snap-ubuntu\x2dbudgie\x2dwelcome-447.mount - Mount unit for ubuntu-budgie-welcome, revision 447.
Aug 13 18:36:48 aung8430 systemd[1]: Mounted snap-ubuntu\x2dbudgie\x2dwelcome-465.mount - Mount unit for ubuntu-budgie-welcome, revision 465.
Aug 13 18:37:02 aung8430 snapd-apparmor[484]: main.go:124: Loading profiles [/var/lib/snapd/apparmor/profiles/snap-confine.snapd.18596 /var/lib/snapd/apparmor/profiles/snap-confine.snapd.19457 /var/lib/snapd/apparmor/profiles/snap-update-ns.firefox /var/lib/snapd/apparmor/profiles/snap-update-ns.snapd-desktop-integration /var/lib/snapd/apparmor/profiles/snap-update-ns.spotify /var/lib/snapd/apparmor/profiles/snap-update-ns.ubuntu-budgie-welcome /var/lib/snapd/apparmor/profiles/snap.firefox.firefox /var/lib/snapd/apparmor/profiles/snap.firefox.geckodriver /var/lib/snapd/apparmor/profiles/snap.firefox.hook.configure /var/lib/snapd/apparmor/profiles/snap.firefox.hook.connect-plug-host-hunspell /var/lib/snapd/apparmor/profiles/snap.firefox.hook.disconnect-plug-host-hunspell /var/lib/snapd/apparmor/profiles/snap.firefox.hook.post-refresh /var/lib/snapd/apparmor/profiles/snap.snapd-desktop-integration.hook.configure /var/lib/snapd/apparmor/profiles/snap.snapd-desktop-integration.snapd-desktop-integration /var/lib/snapd/apparmor/profiles/snap.spotify.hook.configure /var/lib/snapd/apparmor/profiles/snap.spotify.spotify /var/lib/snapd/apparmor/profiles/snap.ubuntu-budgie-welcome.budgie-applets /var/lib/snapd/apparmor/profiles/snap.ubuntu-budgie-welcome.budgie-discourse /var/lib/snapd/apparmor/profiles/snap.ubuntu-budgie-welcome.budgie-themes /var/lib/snapd/apparmor/profiles/snap.ubuntu-budgie-welcome.budgie-welcome /var/lib/snapd/apparmor/profiles/snap.ubuntu-budgie-welcome.hook.install /var/lib/snapd/apparmor/profiles/snap.ubuntu-budgie-welcome.hook.post-refresh /var/lib/snapd/apparmor/profiles/snap.ubuntu-budgie-welcome.hook.remove]
Aug 13 18:37:02 aung8430 audit[504]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap-update-ns.ubuntu-budgie-welcome" pid=504 comm="apparmor_parser"
Aug 13 18:37:02 aung8430 audit[516]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.ubuntu-budgie-welcome.budgie-discourse" pid=516 comm="apparmor_parser"
Aug 13 18:37:02 aung8430 audit[515]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.ubuntu-budgie-welcome.budgie-applets" pid=515 comm="apparmor_parser"
Aug 13 18:37:02 aung8430 audit[517]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.ubuntu-budgie-welcome.budgie-themes" pid=517 comm="apparmor_parser"
Aug 13 18:37:02 aung8430 audit[519]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.ubuntu-budgie-welcome.hook.install" pid=519 comm="apparmor_parser"
Aug 13 18:37:02 aung8430 audit[520]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.ubuntu-budgie-welcome.hook.post-refresh" pid=520 comm="apparmor_parser"
Aug 13 18:37:02 aung8430 audit[518]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.ubuntu-budgie-welcome.budgie-welcome" pid=518 comm="apparmor_parser"
Aug 13 18:37:02 aung8430 audit[521]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.ubuntu-budgie-welcome.hook.remove" pid=521 comm="apparmor_parser"
Aug 13 18:37:14 aung8430 whoopsie-upload-all[809]: INFO:root:/var/crash/_usr_bin_budgie-panel.1000.crash already marked for upload, skipping
Aug 13 18:38:05 aung8430 budgie-wm[1701]: Running Mutter(Budgie) (using mutter 44.3) as a X11 window and compositing manager
Aug 13 18:38:06 aung8430 budgie-wm[1701]: Called enable_unredirect_for_display while unredirection is enabled.
Aug 13 18:38:06 aung8430 budgie-wm[1701]: ibus.vala:47: ibus-daemon unsupported on this system
Aug 13 18:38:06 aung8430 org.buddiesofbudgie.BudgieWm.desktop[1701]: Window manager warning: Failed to parse saved session file: Failed to open file “/home/aung8430/.config/mutter/sessions/10d086ba7186e83571169192667621439800000011800000.ms”: No such file or directory
Aug 13 18:38:06 aung8430 dbus-daemon[538]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service' requested by ':1.68' (uid=1000 pid=1701 comm="/usr/bin/budgie-wm" label="unconfined")
Aug 13 18:38:06 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.49' (uid=1000 pid=1701 comm="/usr/bin/budgie-wm" label="unconfined")
Aug 13 18:38:08 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.51' (uid=1000 pid=1714 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 13 18:38:08 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.51' (uid=1000 pid=1714 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 13 18:38:08 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.51' (uid=1000 pid=1714 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 13 18:38:08 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.51' (uid=1000 pid=1714 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 13 18:38:09 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.51' (uid=1000 pid=1714 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 13 18:38:09 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating service name='com.canonical.AppMenu.Registrar' requested by ':1.51' (uid=1000 pid=1714 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 13 18:38:09 aung8430 org.buddiesofbudgie.BudgiePanel.desktop[1714]: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/com/canonical/AppMenu/Registrar”
Aug 13 18:38:09 aung8430 dbus-daemon[1125]: [session uid=1000 pid=1125] Activating via systemd: service name='org.ayatana.bamf' unit='bamfdaemon.service' requested by ':1.51' (uid=1000 pid=1714 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 13 18:38:12 aung8430 budgie-panel[1714]: notifications_view.vala:187: Unable to connect to notifications dispatcher: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.budgie_desktop.Notifications was not provided by any .service files
Aug 13 18:38:12 aung8430 polkitd(authority=local)[568]: Registered Authentication Agent for unix-session:c2 (system bus name :1.77 [/usr/libexec/budgie-desktop/budgie-polkit-dialog], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Aug 13 18:40:51 aung8430 budgie-wm[1701]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5559a70b40d0] is on because it needs an allocation.
Aug 13 18:40:51 aung8430 budgie-wm[1701]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5559a6620a10] is on because it needs an allocation.
thanks - nothing really interesting there.
is the journalctl log immediately after you saw the “oh no! something has gone wrong” message?
Thats what is needed to indicate hopefully the key issue. Looking on errors.ubuntu.com at around the /var/crash upload date the budgie-desktop issues seem to relate to underlying GTK issues and XServer crashes - not budgie specific. But these would be enough to cause the crash and message you saw.
No, I am still waiting for the incident to happen again to run the command, but unfortunately it haven’t happen today even though the panel still disappear and reappear sometimes…
If you see the panel first appear, then disappear and then reappear, the journalctl log would be useful as well.
I’ve been waiting for it to happen again… Here it is!
Aug 17 18:04:05 aung8430 dbus-daemon[1209]: [session uid=1000 pid=1209] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.48' (uid=1000 pid=1688 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 17 18:04:05 aung8430 dbus-daemon[1209]: [session uid=1000 pid=1209] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.48' (uid=1000 pid=1688 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 17 18:04:05 aung8430 dbus-daemon[1209]: [session uid=1000 pid=1209] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.48' (uid=1000 pid=1688 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 17 18:04:05 aung8430 dbus-daemon[1209]: [session uid=1000 pid=1209] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.48' (uid=1000 pid=1688 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 17 18:04:06 aung8430 dbus-daemon[1209]: [session uid=1000 pid=1209] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.48' (uid=1000 pid=1688 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 17 18:04:06 aung8430 dbus-daemon[1209]: [session uid=1000 pid=1209] Activating service name='com.canonical.AppMenu.Registrar' requested by ':1.48' (uid=1000 pid=1688 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 17 18:04:06 aung8430 org.buddiesofbudgie.BudgiePanel.desktop[1688]: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/com/canonical/AppMenu/Registrar”
Aug 17 18:04:06 aung8430 dbus-daemon[1209]: [session uid=1000 pid=1209] Activating via systemd: service name='org.ayatana.bamf' unit='bamfdaemon.service' requested by ':1.48' (uid=1000 pid=1688 comm="/usr/bin/budgie-panel" label="unconfined")
Aug 17 18:04:07 aung8430 budgie-panel[1688]: notifications_view.vala:187: Unable to connect to notifications dispatcher: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.budgie_desktop.Notifications was not provided by any .service files
Aug 17 18:04:07 aung8430 polkitd(authority=local)[566]: Registered Authentication Agent for unix-session:c2 (system bus name :1.78 [/usr/libexec/budgie-desktop/budgie-polkit-dialog], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Aug 17 18:04:16 aung8430 budgie-panel[1688]: bamf_window_get_xid: assertion 'BAMF_IS_WINDOW (self)' failed
Aug 17 18:04:18 aung8430 budgie-panel[1688]: bamf_window_get_xid: assertion 'BAMF_IS_WINDOW (self)' failed
Aug 17 18:04:18 aung8430 budgie-panel[1688]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 2 does not refer to a menu item we have
Aug 17 18:20:25 aung8430 whoopsie-upload-all[2855]: INFO:root:/var/crash/_usr_bin_budgie-panel.1000.crash already marked for upload, skipping
Aug 17 18:57:01 aung8430 dbus-daemon[537]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.91' (uid=1000 pid=4356 comm="/usr/bin/budgie-control-center mouse" label="unconfined")
Aug 17 18:57:02 aung8430 dbus-daemon[537]: [system] Activating via systemd: service name='org.freedesktop.bolt' unit='bolt.service' requested by ':1.91' (uid=1000 pid=4356 comm="/usr/bin/budgie-control-center mouse" label="unconfined")
Aug 17 19:01:13 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b2ab3b80] is on because it needs an allocation.
Aug 17 19:01:13 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b362abd0] is on because it needs an allocation.
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>4' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>9' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>3' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>8' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>7' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>2' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>1' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>6' failed!
Aug 17 19:28:22 aung8430 budgie-extras-d[1955]: Binding '<Control><Alt>5' failed!
Aug 17 19:35:30 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b33bd0c0] is on because it needs an allocation.
Aug 17 19:35:30 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b33aace0] is on because it needs an allocation.
Aug 17 19:35:31 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b33aace0] is on because it needs an allocation.
Aug 17 19:35:31 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b33bd0c0] is on because it needs an allocation.
Aug 17 19:35:32 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b33aace0] is on because it needs an allocation.
Aug 17 19:35:32 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b33bd0c0] is on because it needs an allocation.
Aug 17 20:29:13 aung8430 kernel: budgie-panel[1688]: segfault at 55a2b6443cd5 ip 00007f06a54eb0d9 sp 00007ffc9e9ee8c0 error 4 in libappmenu-budgie.so[7f06a54d9000+17000] likely on CPU 1 (core 1, socket 0)
Aug 17 20:29:24 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b365d850] is on because it needs an allocation.
Aug 17 20:29:24 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b33bd0c0] is on because it needs an allocation.
Aug 17 20:29:47 aung8430 gnome-session[1259]: gnome-session-binary[1259]: WARNING: Application 'org.buddiesofbudgie.BudgiePanel.desktop' killed by signal 11
Aug 17 20:29:47 aung8430 gnome-session-binary[1259]: WARNING: Application 'org.buddiesofbudgie.BudgiePanel.desktop' killed by signal 11
Aug 17 20:29:47 aung8430 whoopsie-upload-all[8383]: INFO:root:Collecting info for /var/crash/_usr_bin_budgie-panel.1000.crash...
Aug 17 20:29:53 aung8430 whoopsie-upload-all[8383]: INFO:root:Marking /var/crash/_usr_bin_budgie-panel.1000.crash for whoopsie upload
Aug 17 20:29:53 aung8430 whoopsie-upload-all[8383]: INFO:root: missing (remaining: 20 s): /var/crash/_usr_bin_budgie-panel.1000.uploaded
Aug 17 20:29:54 aung8430 whoopsie[8578]: [20:29:54] Parsing /var/crash/_usr_bin_budgie-panel.1000.crash.
Aug 17 20:29:54 aung8430 whoopsie[8578]: [20:29:54] Uploading /var/crash/_usr_bin_budgie-panel.1000.crash.
Aug 17 20:29:58 aung8430 org.buddiesofbudgie.BudgieWm.desktop[1673]: Window manager warning: WM_TRANSIENT_FOR window 0x16001ac for 0x16002bc window override-redirect is an override-redirect window and this is not correct according to the standard, so we'll fallback to the first non-override-redirect window 0x1600018.
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 228 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 236 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 251 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 252 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 326 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 327 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 328 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 329 does not refer to a menu item we have
Aug 17 20:30:11 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 330 does not refer to a menu item we have
Aug 17 20:30:12 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 350 does not refer to a menu item we have
Aug 17 20:30:12 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 360 does not refer to a menu item we have
Aug 17 20:30:12 aung8430 budgie-panel[8386]: DBUSMENU_2dGLIB.Code0: The ID supplied 2048 does not refer to a menu item we have
Aug 17 20:32:12 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 2049 does not refer to a menu item we have
Aug 17 20:32:12 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 2050 does not refer to a menu item we have
Aug 17 20:39:47 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 4755 does not refer to a menu item we have
Aug 17 20:39:47 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 4763 does not refer to a menu item we have
Aug 17 20:39:47 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 4778 does not refer to a menu item we have
Aug 17 20:39:47 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 4779 does not refer to a menu item we have
Aug 17 20:41:49 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 10436 does not refer to a menu item we have
Aug 17 20:41:49 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 10444 does not refer to a menu item we have
Aug 17 20:41:49 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 10459 does not refer to a menu item we have
Aug 17 20:41:49 aung8430 budgie-panel[8386]: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._LIBDBUSMENU_2dGLIB.Code0: The ID supplied 10460 does not refer to a menu item we have
Aug 17 20:42:23 aung8430 kernel: budgie-panel[8386]: segfault at 557d412d4caf ip 00007ff39dfcb0d9 sp 00007fff18351f50 error 4 in libappmenu-budgie.so[7ff39dfb9000+17000] likely on CPU 2 (core 2, socket 0)
Aug 17 20:42:25 aung8430 gnome-session[1259]: gnome-session-binary[1259]: WARNING: Application 'org.buddiesofbudgie.BudgiePanel.desktop' killed by signal 11
Aug 17 20:42:25 aung8430 gnome-session-binary[1259]: WARNING: Application 'org.buddiesofbudgie.BudgiePanel.desktop' killed by signal 11
Aug 17 20:42:25 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b365d850] is on because it needs an allocation.
Aug 17 20:42:25 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b33bd0c0] is on because it needs an allocation.
Aug 17 20:42:25 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b34236e0] is on because it needs an allocation.
Aug 17 20:42:25 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b2b63790] is on because it needs an allocation.
Aug 17 20:42:26 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b365d850] is on because it needs an allocation.
Aug 17 20:42:26 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b33bd0c0] is on because it needs an allocation.
Aug 17 20:42:26 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x5578b34236e0] is on because it needs an allocation.
Aug 17 20:42:26 aung8430 budgie-wm[1673]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x5578b2b63790] is on because it needs an allocation.
Aug 17 20:42:28 aung8430 org.buddiesofbudgie.BudgieWm.desktop[1673]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x1600018
Ok - there is a crash related to the budgie appmenu - interesting!
Have a look in /var/crash for a .crash file around the time of the crash above.
Please can you dropbox this file so that I can have a look at it to see if it contains anything useful.
Here you go!
Fixed by reinstalling the Global Menu Applet. Thanks for the help!
