Hi, I recently pumped into a problem when starting the Lenovo laptop with Budgie. I turn it on for the first time, it will have the “beep beep” sound ring constantly, there is nothing that I can do to stop that noise eventhough I try to press the ON/OFF button, I have to remove the battery for 10 mins then put it back and it start normally. Is there any solution to fix this ? Thanks
Is it immediately after turning the power on? i.e. on the lenovo splash screen?
The fact that you have to remove the battery makes it sounds like a hardware issue. Could be a keyboard key jammed down. Turn the laptop upside down and shake vigorously!
lenova use beeps to identify problem with pc could be memory or any other hardware if its a thinkpad check here Lenovo PC Diagnostics using beep codes - ThinkPad - Lenovo Support US
Yes before the Lenovo logo appears, when the screen still black
That means the operating system hasnt loaded yet. The lenovo efi/bios is doing a system check. Suggest look at the link above.
