Every time i boot to ubuntu budgie it shows me this problem
What is it and how i fix it
Click the “Report problem…” button - it will give you an idea of which component is causing the issue.
Do report things to launchpad when requested (hit the send button).
You can also clear out old crash reports:
sudo rm /var/crash/*
Yes it’s quite common this window shows nothing after hitting [ report problem ] which is a problem in itself
OK but how do i fix this problem?
It worked thanks a lot
