Touchpad gesture
Hi guys,
I’d like to ask if the issue of the touchpad gesture is solved yet? In my case the right-click-button can’t be done yet.
Thx for sharing new infos;)
Cheers
Andi
Sounds like a hardware issue with either the kernel or libinput. Suggest file a bug report
ubuntu-bug linux
Ok thx - going to do this :slight_smile:
I have a new swift laptop. Right click is achieved by tapping on bottom right side with two fingers.
Enabled one finger right click with gnome tweaks.
Ah. Good point. Yeah. Forgot that more modern laptops use two finger tap for a right click. :+1:
