Ubuntu Budgie 23.04 How To Add Budgie PPA's After Upgrade
Hello,
I upgraded from 22.10 to 23.04 I deleted the old PPA entires and need to re-add them for 23.04. Can you help with how to do this?
23.04 already has the latest “everything”.
We will make the daily PPAs available after the first 23.10 daily ISOs are created.
Thank you, will I have to add them manually?
Yes. We will describe the “how” as part of the 23.10 testing thread (to be created)
Ok, thank you for the quick reply. :slight_smile:
