Hello,
I have been using budgie for a week now, loving it to bits.
Being a programmer one of the application I use the most is VSCode, on my keymapping there is a set of shortcuts I use to navigate code: Ctrl+Alt+→ Ctrl+Alt+←
For some reason they seem to be not working on budgie, I was using lxde before, and I had to disable the workspace switching because it was hijacking those two shortcuts, but here I can’t see it anywhere, I disabled 90% of the one using Ctrl+Alt in the keyboard settings menu, and still nothing.
Did anyone get this problem?
