XScreenSaver on Ubuntu budgie possible?
Hello all,
my names is Matt I’ve recently joined this community as I have switched over from Ubuntu Mate to Ubuntu Budgie.
I have been using Linux as my main OS for the last 13 years. Started out on KUbuntu.
The only thing that I’m missing is a decent screensaver on Ubuntu budgie.
Yes I’m not using a CRT so don’t really need one but I still like one.
Is there anyway easily to removing the gnome screensaver / budgie screensaver and replace it with Xsceensaver?
Without uninstalling other parts of the budgie desktop.
Thank you
Hi @cybermaxpower !
Just install Xscreensaver:
sudo apt update && sudo apt install xcreensaver
Then add it to startup applications (right-click on desktop > Desktop Settings > Autostart > Add command):
xscreensaver
Logout and reconnect.
You’ll find Xsreensaver settings in the main menu.
Thank you for your help and pointing in the right direction. I was overthinking it.
I did what you said.
I’ve found out the you need to add
-nosplash to the command on autostart.
Also I disabled the budgie screensaver from autostart.
Thanks :+1:t2:
With pleasure!
Enjoy before UB goes all Wayland!
Yes, or “-no-splash”.
You’re right: always check the options!
 <app name> -h / --help
:+1:
Cool, even if this kind of screen saver doesn’t make sense any more.
“Deco” mode — my favorite:
Thank you for letting me know about XScreenSaver, @cybermaxpower! :grin:
