I was messing around with screensaver, trying to get it to autostart on boot. In the process, I’ve screwed up the budgie desktop - it was basically gone. I’m running Ubuntu 21.10.
I’ve tried uninstalling and re-installing budgie from the command line. Lots of files getting deleted and re-installed, so something is happening. But the budgie Welcome, Applets, etc never show up in my list of Apps. I check in Software Updater, and it says they are there. But nothing actually is there, as far as I can see. Any ideas on how to get budgie back?
Since you are dual booting with ubuntu you need to make a decision - either remove gnome-shell-core to make budgie screensaver work - or try this workaround that may/may not work for you
