Yesterday I updated 21.04 to 21.10 and was looking at the terminal in the meanwhile when I noticed the installer had disabled the lockscreen. I’ve been unable to use it ever since. So far the following yielded no results:
- WIN + L;
- Setting up the blank time to 1 min and automatic lock screen delay to “Screen turns off” (the screen never turns off);
- Re-configuring the display manager and setting it to lightdm;
- Uninstalling gdm3.
The disable-lock-screen dconf setting in org.gnome.desktop.lockdown is not enabled.
Journal logs after pressing WIN+L:
gsd-media-keys: Couldn’t lock screen: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.Shell.ScreenShield was not provided by any .service files
I’m out of ideas, thanks in advance for the help.
What is the output of
ps -ef | grep screensaver
1562 1321 0 18:54 ? 00:00:00 /usr/libexec/gsd-screensaver-proxy
3848 2396 0 19:01 pts/0 00:00:00 grep --color=auto screensaver
ps: added journal logs to main question
ok - gnome-screensaver isn’t running.
It should be autostarted via /etc/xdg/autostart/budgie-desktop-screensaver.desktop - look at the exec= line.
Have you got this?
have you got something in ~/.config/autostart that has a similar exec=gnome-screensaver value? Maybe that is disabling things.
using dconf-editor navigate to org.gnome.desktop.screensaver - use the three dots in the headerbar and choose “Reset visible keys” - this ensures the default screensaver values are being used
You should also reset the visible keys in org.gnome.desktop.lockdown
Update: without doing anything, this morning the screen turns off after specified time and lockscreen works. (Even after multiple restarts, the problem wasn’t being solved before).
Have you got this?
Yes, everything looks fine there.
Nothing there that mentions gnome-screensaver.
I’ll see if the issue comes up again, hopefully not!
Cheers for the help
If the lockscreen appears then gnome-screensaver must be running. Check the process via ps -ef
As to the observation about turning off at a specified time … what do you mean - what time? On a specific interval? Does changing the settings - power blank screen value have any effect?
After restarting the lockscreen stopped working again – ps -ef confirms that gnome-screensaver is not running. No other changes were made since it worked; only power off and power on.
As for the other observation, I meant the screen turns off after the specified inactivity time.
Are you using slick-greeter for your login screen? GDM3 will not work with budgie anymore.
I’ve never actually fiddled with the login screen, so I’m guessing I’m on the default. I tried yesterday to reconfigure my display manager, (re)set it to lightdm. I then even completely removed gdm3.
When you login and check if gnome-screensaver is not running… what happens if you start gnome-screensaver from the command line?
I.e.
gnome-screensaver
I am wondering if you have some sort of race condition where gnome-screensaver is starting too soon. Maybe adding a delayed startup - say 10 seconds would be enough to have gnome-screensaver startup successfully.
gnome-screensaver returns:
** (gnome-screensaver:12584): WARNING **: screensaver already running in this session
but then ps -ef | grep screensaver shows that screensaver is not running.
WIN+L in fact is still not working.
hmm
have you got a file called /usr/share/gnome-shell/org.gnome.ScreenSaver ?
i.e. do you have both gnome-shell and budgie installed? I’m wondering if gnome-shell is interfering here.
I do have that file, this is its content:
imports.package.start({
prefix: '/usr',
libdir: '/usr/lib',
right - so gnome-shell is screwing up budgie here.
Does this work?
pkill -9 -f /usr/bin/gjs /usr/share/gnome-shell/org.gnome.ScreenSaver
Wait a couple of seconds then try running
gnome-screensaver
That allowed me to lock the screen with WIN+L
right … so its question of crafting a bash script now that can be autostarted.
It will need to test if gnome-screensaver is running
if not - run that pkill command above, sleep 5, followed by gnome-screensaver.
So this is what I came up with:
#!/bin/bash
if ps ax | grep -v grep | grep gnome-screensaver > /dev/null
then
echo "gnome-screensaver is not running"
echo "starting gnome-screensaver ..."
pkill -9 -f '/usr/bin/gjs /usr/share/gnome-shell/org.gnome.ScreenSaver'
sleep 3
gnome-screensaver
else
echo "gnome-screensaver already running"
exit
fi
Adding it to startup applications seems to be sufficient to get everything running the way it should.
Cheers for the help
The two pkill commands should just be one as above.
Had to run them separately because your command returns this:
pkill: only one pattern can be provided
Try `pkill --help' for more information.
Ah … missing single quotes
