23.04 - Screen Lock
It seems that again gnome has decided to upend the function of gnome-screensaver enough to prevent it from working in budgie using Lunar Lobster – such that there is never a lock screen presented anymore
I don’t have gnome-shell installed as suggested here
  • Using the “Lock” button provided next to logout/hibernate does nothing
  • Super-L does nothing
  • /usr/bin/gnome-screensaver is running
  • /usr/libexec/gsd-screensaver-proxy is also running
this shows up frequently in /var/log/syslog
Couldn't lock screen: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.ScreenSaver was not provided by any .service files
this log shows up coming from various pids:
  • gsd-media-keys
  • budgie-power-di
  • gsd-usb-protect
I’m not sure what other logs to look through
Can’t reproduce on any of the lunar boxes atm. Is this a default install? Did you by any chance switch resolution/scaling, and are you fully updated?
In addition to what jacob has asked please check if you have the file /usr/bin/gjs installed. It shouldnt be.
I arrived here via a do-release-upgrade -d from kinetic kudu last friday.
aha – this is here.
❯ ls -al /usr/bin/gjs
lrwxrwxrwx 1 root root 11 Apr 11 22:40 /usr/bin/gjs -> gjs-console
Well, it’s my normal 2-monitor setup
xrandr -q
Screen 0: minimum 320 x 200, current 6400 x 2160, maximum 16384 x 16384
eDP-1 connected 2560x1440+0+720 (normal left inverted right x axis y axis) 344mm x 194mm
   3840x2160     60.00 +  60.00
DP-1 connected primary 3840x2160+2560+0 (normal left inverted right x axis y axis) 597mm x 336mm
   3840x2160     60.00 +  29.98*
So, after a purge:
sudo apt purge gjs
sudo apt autoremove
then a session logout/login
i’m still unable to get the lock screen to show up
What does gsettings get org.gnome.desktop.lockdown disable-lock-screen say?
❯ gsettings get org.gnome.desktop.lockdown disable-lock-screen
true
well that’s odd… i’m not sure where in the control center this should be swapped. Lemme set it to false and see what happens.
false
Well! The Lock button in the UI and the Super-L Key is working! Nice
Yay! Glad it worked out.
Still loving this unlocking. @vlijm and @fossfreedom you guys are terrific!
