I have an issue about settings of some applets (raven, budgie weather i noticed so far.). Their settings are coming back to default after restarting computer. By the way i upgraded to 18.10 last week.
Kind Regards,
Kind Regards,
Odd. Haven’t seen that myself.
Please can you reset your panel which will force a clean out of the dconf settings for budgie desktop
Unfortunately it didn’t work. Calendar is still shown up even if i don’t select it.
right - ok for Raven on 18.10 I can confirm this issue. It doesnt though occur with the same version backported to 18.04.
We’ll need to investigate what is happening. There isnt enought time to fix and release before next thursday’s release - but will try to get a fix out as soon as we find what is the problem is and how to resolve.
ok - proposed fix made upstream for the raven settings - need to discuss with upstream first then we’ll backport if this is the correct approach https://github.com/solus-project/budgie-desktop/pull/1596
