As I replied in another post, I looked to see if anyone else posted about this, but didn’t find anything.
First, on two machines, in the list of applets on the top panel in the settings, the last is the Raven Sidebar Control, the penultimate is the User Indicator. What is actually displayed is reversed on both machines until I start moving things around, Raven is penultimate and User is last.
Second, and likely related, when I start moving things around, where they are on the list is not where they actually are on the panel. For instance, I’ll have various applets, a separator, an applet, a separator, User Indicator, Raven, but the two separators will be displayed side-by-side on the panel. They’ll eventually correct (and things go in the correct position) as I move items up then down the list, one after the other, away from and then back into the desired positions.
Third, I’m using the Calendar applet instead of Clock. I have a custom display set. Whenever I restart the computer, I have to rebuild the custom display (which, fortunately, is only adding “:%S” to display seconds); that setting isn’t saved for some reason.
Finally, I have “Show city name” turned off in the Weather applet, yet, when I restart the computer (or log off and back on again), the city name is displayed. The setting is still off, so I have to turn it on and back off again so that the city name isn’t displayed.
Thanks!
