Application menu missing 20.04
small help please. budgie 20.04 my application menu top left suddenly has gone missing. is there a way to bring it back?
Press Alt + f2
Search for budgie desktop settings and then click on the panel on the left pane.
Click the + button and add back the menu of your choice.
thanx! works perfect…
Thanks. also works for 22.04.
It is not a problem actually. It is just a customization new users tweak without knowing the outcome.
