Budgie Extras is 'empty' after upgrade to 21.10
Just empty:
Reinstalling ends up with this message:
After rebooting, it remains ‘empty’ :disappointed_relieved:
Any messages displayed in a terminal if you run the following in a terminal?
budgie-welcome
Then click on the software button and choose budgie-extras
[laptop@laptop ~]$ budgie-welcome
  File "/snap/ubuntu-budgie-welcome/332/usr/bin/budgie-welcome", line 331, in _load_changed_cb
    app.current_page = uri.rsplit('/', 1)[1]
IndexError: list index out of range
what is the output of
budgie-welcome --debug
[laptop@laptop ~]$ budgie-welcome --debug
[Debug] Running in debugging mode.
[Welcome] Using /snap/ubuntu-budgie-welcome/332/usr/share/budgie-welcome/ path.
[i18n] Locale Not Available: null (using en_US instead)
[i18n] All translated i18n pages found.
[i18n] res_dir:
[i18n] Using locale for gettext: null
[i18n] Using path for gettext: /usr/share/locale/
[i18n] Translation found for gettext.
[Network Test] Establishing a connection test to “http://archive.ubuntu.com/”
[Specs] Detecting graphics vendor…
[Welcome] Successfully pinged: http://archive.ubuntu.com/
File “/snap/ubuntu-budgie-welcome/332/usr/bin/budgie-welcome”, line 331, in _load_changed_cb
app.current_page = uri.rsplit(‘/’, 1)[1]
[Specs] Detected: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
locale
Does this behave better?
snap refresh --edge ubuntu-budgie-welcome
You can go back to stable via
snap refresh --stable ubuntu-budgie-welcome
No, sorry, both ideas do not change it.
[laptop@laptop ~]$ locale
LANG=de_DE.UTF-8
LANGUAGE=de_DE
LC_CTYPE=“de_DE.UTF-8”
LC_NUMERIC=“de_DE.UTF-8”
LC_TIME=“de_DE.UTF-8”
LC_COLLATE=“de_DE.UTF-8”
LC_MONETARY=“de_DE.UTF-8”
LC_MESSAGES=“de_DE.UTF-8”
LC_PAPER=“de_DE.UTF-8”
LC_NAME=“de_DE.UTF-8”
LC_ADDRESS=“de_DE.UTF-8”
LC_TELEPHONE=“de_DE.UTF-8”
LC_MEASUREMENT=“de_DE.UTF-8”
LC_IDENTIFICATION=“de_DE.UTF-8”
LC_ALL=
Does this help?
snap remove --purge ubuntu-budgie-welcome
snap install ubuntu-budgie-welcome
Hmmm…
[laptop@laptop ~]$ snap install ubuntu-budgie-welcome
Fehler: Diese Überarbeitung von Snap “ubuntu-budgie-welcome” wurde unter Verwendung der klassischen
Einschränkung veröffentlicht und kann daher möglicherweise beliebige Systemänderungen
außerhalb der Sicherheitssandbox durchführen, in der die Snaps normalerweise eingeschlossen
sind. Dies kann Ihr System gefährden.
    Wenn Sie dies verstehen und fortfahren wollen, wiederholen Sie den Befehl einschließlich
    --classic.
This means:
Error: This revision of snap “ubuntu-budgie-welcome” was released using the classic
restriction, and therefore may be able to perform arbitrary system changes
outside the security sandbox in which the snaps are normally enclosed.
are enclosed. This may put your system at risk.
If you understand this and want to proceed, repeat the command including
–classic.
yep
snap install ubuntu-budgie-welcome --classic
Did not work either. Strange!
Do you mean it didn’t install - or you are still seeing a blank page when the app starts?
Still the blank page.
hmm - not sure.
I switched to de_DE and ran budgie-welcome - it displays in german and budgie-extras shows ok.
I’ve got a problem with Snaps in general, I suppose. I’ve installed EOG for testing as a Snap:
[laptop@laptop ~]$ eog
/snap/eog/602/usr/bin/eog: error while loading shared libraries: libportal.so.0: cannot open shared object file: No such file or directory
[laptop@laptop ~]$
Yeah - I see that as well - that bug needs to be reported to Canonical via launchpad
Ok - I’ve added a debug message at the point of the crash - hopefully that will show me what is going on.
please run
Copy paste the output - thanks.
[Welcome] Using /snap/ubuntu-budgie-welcome/336/usr/share/budgie-welcome/ path.
[i18n] res_dir:
[Debug] uri: file:///snap/ubuntu-budgie-welcome/336/usr/share/budgie-welcome/index.html
[Debug] uri:
File “/snap/ubuntu-budgie-welcome/336/usr/bin/budgie-welcome”, line 332, in _load_changed_cb
ok,
what I am seeing shouldnt ever happen. Why it is I have no idea. Are you using the default python that comes with 21.10?
Anyway - I’ve added a bit of code that will stop the crash - no idea though if it resolves your main issue.
Please run
snap refresh
Let me know what you see.
Good morning!
Yes.
[laptop@laptop ~]$ snap refresh
Alle Snaps sind aktuell.
[Welcome] Using /snap/ubuntu-budgie-welcome/338/usr/share/budgie-welcome/ path.
[i18n] res_dir:
[Network Test] Establishing a connection test to "http://archive.ubuntu.com/"
[Specs] Detecting graphics vendor...
[_load_changed_cb] uri: file:///snap/ubuntu-budgie-welcome/338/usr/share/budgie-welcome/index.html
[_load_changed_cb] weird uri
