Budgie vs Mint, your opinion?
I had Ubuntu Budgie installed then I started trying them all out. I came back to Ubuntu Budgie after Mint 19 (Tara) took 2 1/2 minutes to boot. I even adjusted the boot time and turned off a few of the start up items. (Budgie takes less than a minute to boot - very pleased about that)
Kubuntu kept losing the formatting I set it to, and after a year, I’m just bored with XFCE and Ubuntu proper. The new Lubuntu 18.10 looks interesting, but I understand they are still mid process of porting over to LxQt
Ubuntu Budgie for me - thanks FossFreedom:)
@Coeur-Noir
a couple of pictures that may interest you from the genius mind of team member Jacob
image(1)
(https://github.com/UbuntuBudgie/experimental/tree/master/RecentlyUsed)
TO DO: Needs packaging, testing and adding to budgie-welcome for easy install
Terrific! That’ll come in very handy…
Cinnamon has more of everything. It is a more rounded desktop, and feels closer to win and osx compared with Budgie. But Cinnamon gets slow pretty soon. Feels like an old machine, and in my case, have problems with reboot, halt, and other things (maybe this is related with Mint. I don’t know). Budgie is more simpler, but fast. It is beautiful. Almost everything I need is in there, and it will get better and better from now on. For me Budgie would be better than Cinnamon if the multi screen compatibility gets more solid than now, the corners usage, and the workspaces selection, preview, etc… Otherwise I’m very happy with Budgie. And will change my mint machine (an old iMac) with Budgie like I did with this machine (a PC).
Oh! I also love the background image. Great stuff!
Could you give some more detailed feedback on the corners usage?
Sure. What I’ve tried for the corners is the applet Hot corners. I don’t know if there is another way to set up the corner functionality or this is the only one. And here comes the problem. It doesn’t matter if I tell the applet to use the left or the right side, it uses the whole up section, or the whole down section of the screen. Which means, if I try to open a program from it’s icon in the dock (down-center in my case), the “show desktop” functionality appears… That’s my main problem. And a second one is that I use the corners in Cinnamon mainly for a preview of the workspaces, and to switch spaces “visually”. But that’s only an issue for my personal needs, not necessary for other people.
Could you try to rephrase a bit? I don’t understand what you are saying. The hotcorners applet sets actions on entering the corners. Either prefab ones or custom commands.Not sure where that is not working.
@nanoak, I have two questions:
  1. I have some of the same Hot Corners problems you do. Are you on multi-monitors as I am? I think that’s a big part of it, since those aren’t a problem when I just use Hot Corners on my laptop screen…
  2. For a preview of running apps, I like having a hot corner to activate Skippy-XD. That gives you some of that Cinnamon functionality back.
In my view, many of these DE’s are really converging towards each other. They’re built on much the same parts and have many of the same features, it’s just implementation and speed that separate their usability. I think UB works best “out of the box” of all the DE’s right now, but we’re approaching “tyranny of small differences” territory :slight_smile:.
@vlijm Sorry for my poor English. I’ll try to explain the issue again.
The program is supposed to give you a certain functionality when you hit the corners with the pointer. Show desktop, show open windows, etc… and that’s what I expect. But, if I set for example the show desktop to the top right, it doesn’t trigger the show desktop thing only if I hit the top right. Triggers the show desktop all over the top line. top right, top left, top center… same for the bottom right and left.
I’m working on multi screen with 3 monitors, and I’m sure it is related with that. I can live without the corners app for sure , but it would be great if that would be fixed.
I hope is clear now. If not I’ll search an English translator!
@Iiari didn’t know about the Skippy-XD! Can you tell me how it works?
err404 for the github link ?
May add a second column for recent app’s ? :grin:
( or add all of these ideas « into » Applications Menu Applet, under a « recent » category instead of splitting recent items in many places… )
It has been moved to another repo now. We are kind of by hijacking this thread with this unrelated discussion !
I just came from Linux Mint 19 (Cinnamon). Absolutely everything about that OS is PERFECT…except the massive memory leaks from Cinnamon. It goes from 300mb use at startup, to over 1GB within half an hour, and it brings the system to a crawl. Doing a quick “restart Cinnamon” shortcut-combo will fix the issue, for about 10 minutes, then it has to restart again. This is simply no reason whatsoever that an Intel quad-core with 16GB of RAM should be stuttering and slow from a simple DE. Switched to U-Budgie last night and all my problems are solved! Most of the “applets” I used there are here, more or less, so I haven’t given anything up. Really impressed by the level and ease of customization on Budgie too, it definitely rivals Cinnamon.
One think I really like (I think) is the Plank thing. Takes a lot of getting used to my “taskbar” being on the side, but it makes my most frequently used programs a lot easier to access.
From the menu there is “Plank Preferences” … so you can move bar where-ever you want.
So people also stop plank running (budgie-settings - autostart) and use the budgie icon-task-list applet so that applications appear in the panel rather than in plank.
That’s pretty damn versatile!
Just installed overtop my Ubuntu Budgie, thought I was so excited about elementary OS Juno, … holy crap, no thanks, immediately reinstalled Ubuntu Budgie 18.10
Again, well done everyone - Ubuntu Budgie just feels right, even to this long-time Mac guy.
For those looking for something that looks and “feels” familiar, migrating from Windows to linux, Cinnamon is a great desktop environment. For those wanting to experiment and find something that works for them, then Budgie could be what their looking for. Ranking things like this can become entirely too subjective.
Why not elementary, i’m curious since I don’t know much.
Regarding your topics.
1 - Multiple desktops - OK!
2 - Tabbed terminal - OK!
3 - Not Crash - OK! (at least for me)
You can change the position of the dock to the bottom.
I am running UB for a couple of months and I am very happy with it. I never used Cinammon. But used gnome, kde, mate. and can say the UB is very good indeed.
I am on the LTS version
Earwen, Ubuntu Budgie VS elementary: that’s a good question – I’m from a mac environment, and I was promised the most mac friendly linux experience with elementary. I was SOO looking forward to it, but after I installed it (bare metal, no virtual machines) it just wasn’t what I was hoping for. I like the larger Ubuntu environment. I’ve installed and used Ubuntu (Unity and Gnome) Mint, Xubuntu. Kubuntu, and briefly Solus.
elementary was just too curated for me - I’d like to sort out some stuff on my own. Kudos to the elementary team for creating a positive environment around their distro.
