When I put it in Suspend mode, when it returns it loses the network connection, being necessary to reboot the system
Double check to see if this a tlp issue
sudo apt purge tlp
Reboot then suspend
If the problem still occurs you can reinstall tlp. File a bug report
ubuntu-bug linux
Dear fossfreedom friend, thank you very much for your interest in helping me.
I made his recommendations:
- I totally uninstalled and removed tpl
- I suspended OS
But it does not reconnect the network!
… - I reinstalled tpl
I generated the log, but since I am new here, I can not upload
launchpad.net is the Ubuntu site for all things Ubuntu - including bug reports.
Everyone who uses Ubuntu are strongly recommended to create an account there.
Once you do you can use the command I gave you - this will open up at launchpad.net and ask you for your user name and password. It will then take you to a page for you to fill in details about the bug report. Then it will attach all the logs for you automatically.
Okay, thank you, I’ve already sent the log.
I have also an issue after the suspend, but mine the display server does not work and the entire system becomes “Frozen”
I did submit a bug myself as well
https://bugs.launchpad.net/ubuntu/+source/linux-signed/+bug/1770440
Okay, Bakkar your problem seems more severe, but we both must reboot the OS, let’s wait to see if the bug is fixed.
I have tried the lates upstream Kernel and it works just fine.
Linux #### 4.16.11-041611-generic #201805221331 SMP Tue May 22 17:34:25 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
