A dark-background address bar with clear/white characters is my favourite configuration when using Chromium. However, this feature disappeared when I changed the configuration of the Pocillo-dark theme.
I reset the theme settings and tried to apply the theme again, but the address bar of the Chromium browser persisted with the dark-characters on light-background configuration.
Is there a way to the manipulate directly the address-bar colour?
I didn’t use any kind of command lines. Just applied different themes and changed theme options through Budgie Desktop Settings.
When I realized the problem with Chromium address bar, I used Budgie Welcome options to reinstall Chromium and Budgie Themes to apply the default settings to reset the panel. Both actions didn’t make any difference.
