Hi there! New to Budgie, so sorry in advance if the answer’s right under my nose. ![]()
Is there a way to define the default window size for when I launch a program? Every program (incl. Firefox & Spotify) launch maximized size on first launch after a login/reboot, and I have to adjust that manually. Once I adjust it, if I then reclose the program, it runs with that size, but resets those dimensions again on reboot/relog. It’s a minor inconvenience, and I was wondering if there’s a workaround.
Thanks in advance!
