This seems to be another feature that was broken / removed by switching from Nautilus to Nemo.
It seems that I can no longer keep separate desktop icons / folders on separate monitors.
Instead, it appears to be an ''all or nothing" approach where icons are either 1. Duplicated across both screens 2. Shown only on one of the two screens or 3. Not shown at all
I would like to see the original behaviour restored where different files / icons can be dragged across different screens.
Try the following:
gsettings set org.nemo.desktop use-desktop-grid true
This will give you a customize menu option when you right click.
Click “Desktop Settings” on the customize dialog and choose the desktop layout you want.
Thank you, that worked! May I suggest making this the ‘sane’ default for Ubuntu Budgie’s Nemo settings?
I wish we could - the option stops the ability for users to move icons around unless they first go into the customise option and unticks that autoarrange feature. There doesnt appear to be a way to untick that autoarrange feature.
So the workaround in the other thread to give a right click menu option to enable the grid is a compromise - not what we would want - but better than the terminal action that has to happen now.
I removed nemo a while back to try nautilus and then went back to nemo and have been so confused trying to find that setting somewhere. Thank you for this!
If I understand right, it explains what I just discovered using Budgie on dual monitor : by default if you move an icon from a screen to another, you end up with 2 icons, one on each screen.
If you delete the icon on second screen, it also deletes the same icon on first screen - and the file obviously.
What’s the rationale behind this behavior ? I think it’s confusing.
Another weird thing is : right after install, I saw that « customize menu option » on desktop ( the one with sliders for spacing, right ? ) but now I can’t find it anymore. I probably changed something in Nemo preferences as I often do ( untick any items related to Cinnamon, usually ).
It’s 20.04 here.
