Just have my new work computer online, and working to set it all up.
I work with dual monitors. Both monitors are up fine, but I can only use one of them. The mouse will not pass over to the left screen…
I suppose it is an easy adjustment, but I cannot find it.
Any suggestions?
Do check Menu - Displays that both monitors are shown and that the orientation is correct e.g. if the monitors are shown vertically then the mouse cursor will move up/down. Drag the monitor boxes around on that settings display to change the orientation.
Have found a new issue.
I can drag a open window from my right main screen over to the left screen.
But only half ways. I can can move the mouse all over both screens.
I presume you have a panel on the left side of the primary screen?
You cannot move windows left/right with a panel on the primary screen - that is a X Windowing system limitation. If you set the left panel to autohide then the window can be dragged across screens.
