After install the Ethernet worked great, but after some reboots the ethernet connection is lost and i can’t even detect the ethernet card anymore.
Did a sudo lshw -C network, only WIFI is detected, no Ethernet (enx…).
This problem is known with Realtek 8152 or 8153 USB-C Ethernet cards.
A fix was to stop TLP to send certain USB devices to auto-suspend, because they won’t wake anymore.
Ethernet Realtek 8153 (Dell WD15 Dock fix)
sudo gedit /etc/default/tlp
add this lines to the file:
USB_BLACKLIST="0bda:8153"
USB_BLACKLIST="0bda:8152"
Save & reboot.
This usually worked.
According to the new Ubuntu Budgie version changelog it does not have TLP installed anymore, because of many bugs.
But the Ethernet card is gone again.
Please help.
pappl
