Export Budgie Desktop settings to another session?
I’m rather happy with one session. I’d like to « export » its configuration to other users-sessions.
I mean the Budgie-panels and applets - not necessarily themes and icons.
Looking through ~/.config and other hidden files, I can’t see what to copy-paste…
…maybe not that easy, or another way ( dconf ? )
This was a project that was started on the 20.04 cycle but was not finished
It will give you an idea of what to do. If it inspires you, feel free to help out with a patch or two big or small. Thx
Usually I do this way: dump dconf configurations that I want to export, eg:
dconf dump /org/ubuntubudgie/plugins/budgie-showtime/ > showTime.dconf
and load it by the means of a script like
dconf load /org/ubuntubudgie/plugins/budgie-showtime/ < showTime.dconf
Otherwise is possible to save and replace .config/dconf/user from one user to another but doing that in chroot when building my customized iso not always works (and don’t ask me why :wink: )
Sil
Indeed !
I did a dump dconf like this :
dconf dump /com/solus-project/ > /home/other_user/Bureau/budgie-dconf-dump
and then load in the other session with
dconf load /com/solus-project/ < ~/Bureau/budgie-dconf-dump
I just had to tweak a bit some applets settings, showtime and pixel-saver if i remind correctly.
…which sounds logical since those are not stored in dconf com.solus-project but in org.ubuntubudgie if I understand right.
This helped me Cloud sync all budgie-settings / backup & restore
Thanks a lot @fossfreedom and @puffettacicciottella
Next time I’ll also dump
dconf dump /org/ubuntubudgie/ > /home/other_user/Bureau/ubuntubudgie-dconf-dump
pas de quoi; on s’aide, n’est-ce pas? :grin:
Sylviette
Thank you all for this discussion. Good to learn about this! I’m thinking of redoing my partition setup, so this would save me a little time post-install.
In my case I’m doing both of these, then backing up the dump files for later import using “dconf load”:
dconf dump /org/ubuntubudgie/ > budgie-dconf-dump
dconf dump /com/solus-project/ > solus-dconf-dump
