…not knowing where it comes from and what it sends, if it sends anything to anyone ?
And as you may see, only that dialog box is displayed, no matching icon in icon-tasks-list in panel and no other window appears when I hit « signaler le problème / report bug » ( such as apport or sort ).
Where should I look at ?
It happens once at each start and no more. Comes back at next reboot. My system seems to work normally though.
Probably - clicking the “send” button should take you to launchpad to file the report. There you will be autolinked to the package causing the issue. The message though shows the culprit - looks very much like the package needs a tweak or two to make it python 3.8 compatable
