HPLiP / HPLiP toolbox : broken in Budgie?
was trying to troubleshoot an old HP4180 deskjet AiO printer, so I may need HPLiP utilities.
HPLiP is a Qt4 app and looks like this on Unity16.04 :
It’s also a kind of indicator in the tray.
Am on UBudgie 18.04 and it looks like this, too big, almost impossible to move around and missing core elements :
Note also after I’ve tried to launch it on Ubudgie18.04, all desktop became almost unresponvive :
see « unable to grab cursor » in terminal, as I was able to move mouse cursor but click was uneffective.
HPLiP is THE tool regarding HP printers, I know it’s not your fault if it’s written in Qt4 but maybe find a workaround ? Or may I miss some packages ?
On the same machine, booted on same kernel, same base system 18.04, but with another user and Unity DE :
So there’s something in Budgie that prevents HPlip gui from working ?
And it also seems I do not miss any package regarding qt4 - that would not work either in that Unity session.
18.04 UB here - I’m seeing this
Same screen with 19.10 :slight_smile:
O.o damn… so where to look for ? And look for what ?
Have a look at the .desktop file in /usr/share/applications.
Look at the exec= line.
Run the command after exec= in a terminal.
Any messages displayed that may give a hint to what the issue is?
Try this:
sudo apt install hplip hplip-gui hplip-data hplip-doc hpijs-ppds libsane-hpaio printer-driver-hpcups printer-driver-hpijs.
Here:
As stated above, hplip gui works in an another session ( unity ) on that same machine and system so I don’t think packages are missing. Will check anyway.
coeur-noir@asgard:~$ sudo apt install hplip hplip-gui hplip-data hplip-doc hpijs-ppds libsane-hpaio printer-driver-hpcups printer-driver-hpijs
[sudo] Mot de passe de coeur-noir :
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
hplip est déjà la version la plus récente (3.17.10+repack0-5).
hplip-data est déjà la version la plus récente (3.17.10+repack0-5).
hplip-doc est déjà la version la plus récente (3.17.10+repack0-5).
libsane-hpaio est déjà la version la plus récente (3.17.10+repack0-5).
printer-driver-hpcups est déjà la version la plus récente (3.17.10+repack0-5).
hplip-gui est déjà la version la plus récente (3.17.10+repack0-5).
Les NOUVEAUX paquets suivants seront installés :
  hpijs-ppds printer-driver-hpijs
0 mis à jour, 2 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 389 ko dans les archives.
Après cette opération, 2 392 ko d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n] o
Réception de :1 http://fr.archive.ubuntu.com/ubuntu bionic/main amd64 printer-driver-hpijs amd64 3.17.10+repack0-5 [296 kB]
Réception de :2 http://fr.archive.ubuntu.com/ubuntu bionic/universe amd64 hpijs-ppds all 3.17.10+repack0-5 [93,4 kB]
389 ko réceptionnés en 0s (884 ko/s)
Sélection du paquet printer-driver-hpijs précédemment désélectionné.
(Lecture de la base de données... 507323 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../printer-driver-hpijs_3.17.10+repack0-5_amd64.deb ...
Dépaquetage de printer-driver-hpijs (3.17.10+repack0-5) ...
Sélection du paquet hpijs-ppds précédemment désélectionné.
Préparation du dépaquetage de .../hpijs-ppds_3.17.10+repack0-5_all.deb ...
Dépaquetage de hpijs-ppds (3.17.10+repack0-5) ...
Paramétrage de printer-driver-hpijs (3.17.10+repack0-5) ...
Paramétrage de hpijs-ppds (3.17.10+repack0-5) ...
Traitement des actions différées (« triggers ») pour man-db (2.8.3-2ubuntu0.1) ...
Traitement des actions différées (« triggers ») pour cups (2.2.7-1ubuntu2.7) ...
Updating PPD files for hpijs-ppds ...
Updating PPD files for hpijs ...
Still the same problem. Notice also that once hplip tools is open I can no longer use the printscreen key and all interaction with Budgie shell ( panels, window controls ) become slooooow, and the icon in systray displays no menu at richt or left click. Have to use the system monitor to quit hplip.
Here are the messages :
coeur-noir@asgard:~$ hp-toolbox
HP Linux Imaging and Printing System (ver. 3.17.10)
HP Device Manager ver. 15.0
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
(python3:31757): Gtk-CRITICAL **: 22:23:53.591: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:53.593: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:53.594: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:53.602: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:53.603: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:53.605: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
System Tray Status Service ver. 2.0
(python3:31757): Gtk-CRITICAL **: 22:23:54.636: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:54.637: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:54.639: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:54.640: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:54.642: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:54.785: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:55.208: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:55.209: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:55.218: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:55.219: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:55.220: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:55.323: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
error: Unable to communicate with device (code=12): hp:/usb/Deskjet_F4100_series?serial=CN7883Z02N04TJ
error: Device not found
(python3:31757): Gtk-CRITICAL **: 22:23:56.086: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:56.088: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:56.089: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:57.111: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:57.112: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
(python3:31757): Gtk-CRITICAL **: 22:23:57.335: IA__gtk_widget_style_get: assertion 'GTK_IS_WIDGET (widget)' failed
Hmm, it seems to be an issue with the GTK2 style for Qt. Get Qt5ct (sudo apt install qt5ct), also see Can't use Qt5ct to change global application style to kvantum.
open qt5 settings from the menu, and change the style (to e.g. fusion). This will temporarily make qt5 apps use an old style. Afterwards, try again. If the issue is solved, I recommend you install Kvantum ( https://github.com/tsujan/Kvantum/tree/master/Kvantum) and choose one of those themes :slight_smile:
I am using Pocillo gtk theme with Pocillo icons … if you are not using those does switching to Pocillo make a difference?
I thought I had mentioned it already or maybe I did not edit my first message.
It behaves exactly the same with default pocillo theme / icons / widgets. Here on another user with default settings :
( by the way that picture also illustrates the problem about overlapping panel / height mismatch, see Top horizontal panel overlapping, if height < 41 px ).
Am I missing some package⋅s in the gtk realm ?
coeur-noir@asgard:~$ dpkg -l | grep gtk
ii  adapta-gtk-theme                        3.95.0.11-0ubuntu1~bionic1                      all          Adapta Gtk+ Theme
ii  adobe-flash-properties-gtk              1:20191009.1-0ubuntu0.18.04.1                   amd64        GTK+ control panel for Adobe Flash Player plugin
ii  appmenu-gtk-module-common               0.6.94-1                                        all          Common files for GtkMenuShell D-Bus exporter
ii  appmenu-gtk2-module:amd64               0.6.94-1                                        amd64        GtkMenuShell D-Bus exporter (GTK+2.0)
ii  appmenu-gtk3-module:amd64               0.6.94-1                                        amd64        GtkMenuShell D-Bus exporter (GTK+3.0)
ii  apport-gtk                              2.20.9-0ubuntu7.9                               all          GTK+ frontend for the apport crash report system
ii  gir1.2-gtk-3.0:amd64                    3.22.30-1ubuntu4                                amd64        GTK+ graphical user interface library -- gir bindings
ii  gir1.2-gtkchamplain-0.12:amd64          0.12.16-2                                       amd64        Gtk+ widget to display maps (GObject introspection)
ii  gir1.2-gtkclutter-1.0:amd64             1.8.4-3                                         amd64        GObject introspection data for the GTK+ Clutter library
ii  gir1.2-gtksource-3.0:amd64              3.24.7-1                                        amd64        gir files for the GTK+ syntax highlighting widget
ii  gir1.2-javascriptcoregtk-4.0:amd64      2.26.2-0ubuntu0.18.04.1                         amd64        JavaScript engine library from WebKitGTK+ - GObject introspection data
ii  gstreamer1.0-gtk3:amd64                 1.14.5-0ubuntu1~18.04.1                         amd64        GStreamer plugin for GTK+3
ii  gtk-update-icon-cache                   3.22.30-1ubuntu4                                amd64        icon theme caching utility
ii  gtk2-engines-murrine:amd64              0.98.2-2ubuntu1                                 amd64        cairo-based gtk+-2.0 theme engine
ii  gtk2-engines-pixbuf:amd64               2.24.32-1ubuntu1                                amd64        pixbuf-based theme for GTK+ 2.x
ii  gtk3-nocsd                              3-1ubuntu1                                      all          Disable Gtk+ 3 client side decorations (CSD)
ii  gtkdialog                               2:0.8.3-2                                       amd64        GUI-creation command-line utility based on GTK+ library
ii  handbrake-gtk                           1:1.2.1-zhb-1ppa1~bionic1                       amd64        versatile DVD ripper and video transcoder - GTK GUI
ii  ibus-gtk:amd64                          1.5.17-3ubuntu5.2                               amd64        Intelligent Input Bus - GTK+2 support
ii  ibus-gtk3:amd64                         1.5.17-3ubuntu5.2                               amd64        Intelligent Input Bus - GTK+3 support
ii  libappmenu-gtk2-parser0:amd64           0.6.94-1                                        amd64        GtkMenuShell to GMenuModel parser (GTK+2.0)
ii  libappmenu-gtk3-parser0:amd64           0.6.94-1                                        amd64        GtkMenuShell to GMenuModel parser (GTK+3.0)
ii  libavahi-ui-gtk3-0:amd64                0.7-3.1ubuntu1.2                                amd64        Avahi GTK+ User interface library for GTK3
ii  libcanberra-gtk-module:amd64            0.30-5ubuntu1                                   amd64        translates GTK+ widgets signals to event sounds
ii  libcanberra-gtk0:amd64                  0.30-5ubuntu1                                   amd64        GTK+ helper for playing widget event sounds with libcanberra
ii  libcanberra-gtk3-0:amd64                0.30-5ubuntu1                                   amd64        GTK+ 3.0 helper for playing widget event sounds with libcanberra
ii  libcanberra-gtk3-module:amd64           0.30-5ubuntu1                                   amd64        translates GTK3 widgets signals to event sounds
ii  libchamplain-gtk-0.12-0:amd64           0.12.16-2                                       amd64        Gtk+ widget to display maps
ii  libcheese-gtk25:amd64                   3.28.0-1ubuntu1                                 amd64        tool to take pictures and videos from your webcam - widgets
ii  libclutter-gtk-1.0-0:amd64              1.8.4-3                                         amd64        Open GL based interactive canvas library GTK+ widget
ii  libcolord-gtk1:amd64                    0.1.26-2                                        amd64        GTK+ convenience library for interacting with colord
ii  libdbusmenu-gtk3-4:amd64                16.04.1+18.04.20171206-0ubuntu2                 amd64        library for passing menus over DBus - GTK+ version
ii  libdbusmenu-gtk4:amd64                  16.04.1+18.04.20171206-0ubuntu2                 amd64        library for passing menus over DBus - GTK+ version
ii  libgtk-3-0:amd64                        3.22.30-1ubuntu4                                amd64        GTK+ graphical user interface library
ii  libgtk-3-bin                            3.22.30-1ubuntu4                                amd64        programs for the GTK+ graphical user interface library
ii  libgtk-3-common                         3.22.30-1ubuntu4                                all          common files for the GTK+ graphical user interface library
ii  libgtk2-perl                            2:1.24992-1build1                               amd64        Perl interface to the 2.x series of the Gimp Toolkit library
ii  libgtk2.0-0:amd64                       2.24.32-1ubuntu1                                amd64        GTK+ graphical user interface library
ii  libgtk2.0-bin                           2.24.32-1ubuntu1                                amd64        programs for the GTK+ graphical user interface library
ii  libgtk2.0-common                        2.24.32-1ubuntu1                                all          common files for the GTK+ graphical user interface library
ii  libgtk3-nocsd0:amd64                    3-1ubuntu1                                      amd64        Library to disable Gtk+ 3 client side decorations (CSD)
ii  libgtk3-perl                            0.032-1                                         all          Perl bindings for the GTK+ graphical user interface library
ii  libgtkd-3-0                             3.7.5-2build1                                   amd64        GTK+ graphical user interface library - D bindings
ii  libgtkglext1:amd64                      1.2.0-8                                         amd64        OpenGL Extension to GTK+ (shared libraries)
ii  libgtkmm-2.4-1v5:amd64                  1:2.24.5-2                                      amd64        C++ wrappers for GTK+ (shared libraries)
ii  libgtkmm-3.0-1v5:amd64                  3.22.2-2                                        amd64        C++ wrappers for GTK+ (shared libraries)
ii  libgtksourceview-3.0-1:amd64            3.24.7-1                                        amd64        shared libraries for the GTK+ syntax highlighting widget
ii  libgtksourceview-3.0-common             3.24.7-1                                        all          common files for the GTK+ syntax highlighting widget
ii  libgtkspell0:amd64                      2.0.16-1.2                                      amd64        spell-checking addon for GTK's TextView widget
ii  libido3-0.1-0:amd64                     13.10.0+17.04.20161028-0ubuntu1                 amd64        Shared library providing extra gtk menu items for display in
ii  libjavascriptcoregtk-4.0-18:amd64       2.26.2-0ubuntu0.18.04.1                         amd64        JavaScript engine library from WebKitGTK+
ii  libnm-gtk0:amd64                        1.8.10-2ubuntu3                                 amd64        library for wireless and mobile dialogs (libnm-glib version)
ii  libreoffice-gtk3                        1:6.0.7-0ubuntu0.18.04.10                       amd64        office productivity suite -- GTK+ 3 integration
ii  libwebkit2gtk-4.0-37:amd64              2.26.2-0ubuntu0.18.04.1                         amd64        Web content engine library for GTK+
ii  libwebkit2gtk-4.0-37-gtk2               2.26.2-0ubuntu0.18.04.1                         all          Transitional dummy package
ii  libwmf0.2-7-gtk                         0.2.8.4-12                                      amd64        Windows metafile conversion library
ii  libwxgtk3.0-0v5:amd64                   3.0.4+dfsg-3                                    amd64        wxWidgets Cross-platform C++ GUI toolkit (GTK+ runtime)
ii  libwxgtk3.0-gtk3-0v5:amd64              3.0.4+dfsg-3                                    amd64        wxWidgets Cross-platform C++ GUI toolkit (GTK+ 3 runtime)
ii  materia-gtk-theme                       20180321-1                                      all          Material Design theme for GNOME/GTK+ based desktop environments
ii  overlay-scrollbar-gtk2:amd64            0.2.17.1+16.04.20151117-0ubuntu2                amd64        GTK 2 module for overlay scrollbars
ii  paper-gtk-theme                         2.1+r265~daily~ubuntu16.10.1                    all          Paper GTK Theme
ii  python-gtk2                             2.24.0-5.1ubuntu2                               amd64        Python bindings for the GTK+ widget set
ii  python-wxgtk3.0                         3.0.2.0+dfsg-7                                  amd64        Python interface to the wxWidgets Cross-platform C++ GUI toolkit
ii  python3-aptdaemon.gtk3widgets           1.1.1+bzr982-0ubuntu19.1                        all          Python 3 GTK+ 3 widgets to run an aptdaemon client
ii  qt5-gtk-platformtheme:amd64             5.9.5+dfsg-0ubuntu2.4                           amd64        Qt 5 GTK+ 3 platform theme
ii  software-properties-gtk                 0.96.24.32.11                                   all          manage the repositories that you install software from (gtk)
ii  transmission-gtk                        2.92-3ubuntu2                                   amd64        lightweight BitTorrent client (GTK+ interface)
ii  ubuntu-release-upgrader-gtk             1:18.04.36                                      all          manage release upgrades
ii  usb-creator-gtk                         0.3.5ubuntu18.04.2                              amd64        create a startup disk using a CD or disc image (for GNOME)
ii  xdg-desktop-portal-gtk                  1.2.0-flatpak1~bionic                           amd64        GTK+/GNOME portal backend for xdg-desktop-portal
ii  xdg-user-dirs-gtk                       0.10-2                                          amd64        tool to manage well known user directories (Gtk extension)
Or do I have too much here ?
Mmm… I really don’t think it’s a problem with Qt since it works in another session / another user on the same base-system but another DE ( Unity instead of Budgie ).
Maybe the problem is here : do you know if Budgie and Unity live nicely together on the same system ( but separate users ) ?
So if you use the unity user but login to budgie desktop what happens?
It seems to be the problem, if i understand you installed unity on UB and the application launches on UB, or do you mean you have a dualboot system with stock Ubuntu and Unity + UB?
(UB=Ubuntu Budgie)
It does seem to be a user config problem
My religion forbids me to use more than one DE by user, lol !
Joke aside it’s the best way to have mismatching config’ files regarding DE.
But I don’t care to break my Unity session now as it’s almost empty.
So, logging with Unity user but in a Budgie session gives that :
where you can clearly see the mismatches between unity config ( ambiance theme ) and budgie.
Reason why thou shall never user different DE under one user !
And HPLiP tool box, broken.
Lol ok, so you have different users?
Many users. And many systems, currently only 2, ubuntu 16.04 unity in a partition where I do my serious and important things, and UBudgie 18.04 in another partition for testing, tweaking, breaking… 3 users on each system. Therefore dual-boot.
Ah okay. Try the qt5ct fix I mentioned in that case.
And after all that, if I go back in my Unity session in that 18.04 system, all is fine for HPLiP tool so what’s happening here by me ? Why is it correctly displayed only in Unity, and has never been displayed correctly in Budgie, even before I install Unity ???
( I have installed Unity here on 18.04 only to check if HPLiP tool would work there as in 16.04… )
So something in my Budgie sessions might prevent me to use HPLiP tool ?
