Hi, thanks for all your great work on UbuntuBudgie. I hope I’m posting in the right place.
Just updated to 18.04 and had no major issues so far. This is bothering me though…
For locking, you have chosen gnome-screensaver (with modifications). It looks great!
When ending a session (logging out), I’m greeted by lightdm slick-greeter. Which also looks good!
Wouldn’t it make sense for both of them to be the same?
My preference would be the lock screen look (so gnome-screensaver)
I found this open issue in budgie-artwork https://github.com/UbuntuBudgie/budgie-artwork/issues/3 which I think illustrates a similar issue.
Is this the desired behaviour, and if so, how can I work around it, can I enable automatic session login and force lockscreen on session start?
Thanks, keep up the good work!
