Is it possible to pin AppImages to Panel?
Is it possible to pin AppImages (running AppImages) to the panel? I believe to the Icon Task List applet?
I’m guessing you can’t pin snaps either (option to pin not available) :frowning:
does the recommendation here work with appimages?
The xprop workaround did the trick for AppImages.
