Hi
Upgraded yesterday from 21.10 to 22.04 and got following issue, which may or may not be Budgie specifically related, probably more an incompatibility of the laptops GPU with the kernel.
- screen tear - seen loads on Goggle relating too this and am going to suggest is kernel orientated?
If on boot up I go back to previous kernel still running 22.04 though (when you do lsb_release) is fine but kernel 5.15.0-27 is tearing it up even when i have lowered the refresh rate, tried to add a file to the xorg.conf.d folder (all the stuff on google) basically. any ideas please?
Thanks
