Below are my details
apanta@apanta-desktop:~$ inxi -FZRa
System:
Host: apanta-desktop Kernel: 5.19.0-32-generic x86_64 bits: 64
compiler: N/A parameters: BOOT_IMAGE=/boot/vmlinuz-5.19.0-32-generic
root=UUID=8d3fddc3-603e-4cdb-aab2-62bd896da1d0 ro quiet splash
Desktop: Budgie 10.6.1 info: budgie-panel, plank, vala-panel
wm: budgie-wm dm: LightDM 1.30.0
Distro: Ubuntu 22.04.3 LTS (Jammy Jellyfish)
Machine:
Type: Desktop Mobo: ASRock model: K10N78FullHD-hSLI..
serial: <superuser required> BIOS: American Megatrends v: P2.30
date: 04/30/2010
CPU:
Info: model: AMD Athlon 64 X2 5200+ bits: 64 type: MCP arch: K8 rev.F+
family: 0xF (15) model-id: 0x6B (107) stepping: 2 microcode: N/A
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 256 KiB
desc: d-2x64 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
Speed (MHz): avg: 1000 min/max: 1000/2700 scaling: driver: powernow-k8
governor: schedutil cores: 1: 1000 2: 1000 bogomips: 10799
Flags: ht lm nx pae sse sse2 sse3 svm
Vulnerabilities:
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data status: Not affected
Type: retbleed status: Not affected
Type: spec_store_bypass status: Not affected
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: NVIDIA C77 [GeForce 8200] vendor: ASRock K10N78FullHD-hSLI R3.0
driver: N/A alternate: nvidiafb, nouveau bus-ID: 02:00.0 chip-ID: 10de:0849
class-ID: 0300
Device-2: NVIDIA GF106 [GeForce GTS 450] driver: nouveau v: kernel
alternate: nvidiafb pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: VGA-1 empty: DVI-I-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 10de:0dc4
class-ID: 0300
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:2 chip-ID: 046d:081b class-ID: 0102 serial: 23CC4900
Display: x11 server: X.Org v: 1.21.1.4 compositor: budgie-wm driver: X:
loaded: modesetting unloaded: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: VGA-1 model: BenQ GW2480 serial: E6N0327801Q built: 2022
res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: NVC3 v: 4.3 Mesa 23.0.4-0ubuntu1~22.04.1
direct render: Yes
Audio:
Device-1: NVIDIA MCP72XE/MCP72P/MCP78U/MCP78S High Definition Audio
vendor: ASRock K10N78FullHD-hSLI R3.0 driver: snd_hda_intel v: kernel
bus-ID: 00:07.0 chip-ID: 10de:0774 class-ID: 0403
Device-2: NVIDIA GF106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 10de:0be9 class-ID: 0403
Device-4: TerraTec GmbH Aureon Dual USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 6-1:2 chip-ID: 0ccd:0077
class-ID: 0300
Sound Server-1: ALSA v: k5.19.0-32-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: NVIDIA MCP77 Ethernet vendor: ASRock K10N78FullHD-hSLI R3.0
driver: forcedeth v: kernel port: 9880 bus-ID: 00:0a.0 chip-ID: 10de:0760
class-ID: 0200
IF: enp0s10 state: down mac: 00:19:66:95:bb:3a
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: TP-LINK TG-3468 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e800 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 50:3e:aa:0d:94:6e
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 4.32 TiB used: 450.47 GiB (10.2%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: S2RBNXAH108619N rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1ER164
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: Z4Z1QG3Y rev: CC25 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST31000528AS
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: 9VP9W7X3 rev: CC38 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: SSD serial: 2143E5DBAF7B rev: 043 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: 2205E6065CFA rev: 060 scheme: MBR
Partition:
ID-1: / raw-size: 50.3 GiB size: 49.21 GiB (97.83%) used: 14.97 GiB (30.4%)
fs: ext4 dev: /dev/sde2 maj-min: 8:66
Swap:
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda1 maj-min: 8:1
Sensors:
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nouveau temp: 38.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Info:
Processes: 218 Uptime: 50m wakeups: 2442 Memory: 7.27 GiB
used: 1.66 GiB (22.9%) Init: systemd v: 249 runlevel: 5 tool: systemctl
Compilers: gcc: 11.4.0 alt: 11/12 Packages: 2074 apt: 2063 lib: 1072
snap: 11 Shell: Bash v: 5.1.16 running-in: tilix inxi: 3.3.13
This morning I updated the operating system. to the latest kernel (6.5.0-14) which corrupted my nvidia drivers, as listed below:
Processing errors occurred:
nvidia-dkms-390
nvidia-driver-390
E: Sub-process /usr/bin/dpkg returned an error code
as well as inhibiting the operation of the various launchers on the dock at the bottom
while the s.o. starts regularly with kernel6.2.0-39.
the question: how can I delete the latest kernel? and if so, how?
thanks for your support
