Kangaroo Applet with no icons
Hi! I am trying the “Kangaroo” applet on Manjaro Budgie. Overall it work fine but there are no icons for the folders. Kangaroo-No-Icons
Any idea how to fix that?
Looks like you have the dconf setting org.gnome.desktop.interface menu-have-icons switch to “True”.
Odd setting to have on - Kangaroo doesn’t support this option. Try turning that option to False via dconf-editor
I don’t have “menu-have-icons” there.
dconf-interface
hmm - it might be then a regression with GTK+3.24.
Its a python based applet so if you have any experience, you might want to have a dig in there.
Lol. No experience at all.
I just thought that I was missing some kind of “fonts”, that is why I opened this topic.
Thank you, I am leaving it as it is. Hopefully some day it will be updated or replaced with a better applet.
hmm - you are right - in the code its a unicode folder character. What font are you using?
I am sorry, I am not an expert, where can i see this?
budgie-desktop-settings - fonts
Budgie-Desktop-Settings-Fonts
hmm - I cannot reproduce on Ubuntu Budgie 19.04 with your fonts settings. So I’m not really sure why Manjaro isn’t displaying stuff correctly :frowning:
I had same issue with “lsd” the new “ls” command.
LSD
and fixed that after installing recommended fonts:
-ttf-nerd-fonts-symbols
-nerd-fonts-terminus
-awesome-terminal-fonts
and after the installation icons were fixed:
lsd-OK
This is why i thought the Kangaroo issue should be same.
PS: second picture is after i installed “powerline-shell”.
Fond the solution on Manjaro Forums.
installed “noto-fonts” package.
Kangaroo-noto-fonts
thanks. We’ll add that as a runtime dependency in the README.
