My 25.10 --> 26.04 upgrade experience. Many things went wrong
I was prompted to upgrade to 26.04. The installation process was 99% OK. But things went worse upon reboot.
I was not presented with the graphical logon page. Instead I was presented with a text terminal logon. I had no idea how to get the desktop environment restored, and so I took to google gemini to get some answers. Along the way, I upgraded my Nvidia drivers from 580 to 595, clutching at straws (it didn’t help, but it didn’t wreck anything else). There was a lot of unsuccessful suggestions, but this one got me to the graphical logon, persistenly following a reboot.
sudo systemctl disable sddm.service
sudo systemctl enable --force sddm.service
sudo mkdir -p /etc/systemd/system/graphical.target.wants
sudo ln -sf /lib/systemd/system/sddm.service /etc/systemd/system/graphical.target.wants/sddm.service
sudo systemctl daemon-reload
sudo reboot
I can’t say I knew what I was doing here, but my next challenge was that I had a white background for the login page. My previous picture shown on /usr/share/backgrounds wasn’t showing. No matter what I did to the theme.conf file, it was just showing a white background. It took a lot of gemini suggestions, but eventually this did the job:
sudo slicksddm-customize --set “General/use-accounts-service-backgrounds=false”
sudo systemctl restart sddm
Again, no idea what I did there.
I had three screens, and their displays were all sitting right ontop of each other. I managed to separate them out using the wdisplays application.
I had the old dock, and the new dock sitting one above the other. I had to force the new dock onto the left hand edge of the left hand screen, otherwise the application launchers were frozen.
killall crystal-dock
sed -i ‘s/position=[0-3]/position=2/’ ~/.config/crystal-dock/Budgie/panel_1.conf
nohup crystal-dock > /dev/null 2>&1 &*
Wallstreet no longer worked, so I disabled it. I installed apt Variety in it’s place to get my changing background images back.
A number of apps installed from apt didn’t work:
  • OBS Studio → apt remove, flatpak installed
  • Shotcut would only run correctly once I started it with this command:
    env QT_QPA_PLATFORM=xcb shotcut
All told: 26.04 upgrade was a bad experience. It took about 6 hours to figure this all out. I could imagine that while it “just works” as a fresh install, it would be a gunshot to someone elses confidence if they didn’t know how to get past the text logon to the familiar graphical interface. Thankfully I have the presense of mind to take a backup image of my machine prior to upgrade, so I had a reverse gear if I couldn’t fix this..
Previously my upgrade from 24.10 → 25.04 → 25.10 was uneventful.
I’ve still got a windows program on wine that crashes after a few minutes to fix (CLS2Sim), so I’m not 100% back to the way things were, but I’m getting there.
X-Plane 12 can’t be pinned to the dock either.
I’m wondering if you are missing either ubuntu-budgie-desktop or ubuntu-budgie-desktop-minimal meta packages. Without it the upgrader would not have installed all the requisite packages - and worse might have removed key packages. budgie-desktop-environment is a key package as well - if that had gone awry then many budgie related packages wouldn’t have been installed
The white screen probably meant the key budgie-sddm-theme package wasn’t installed - hence my immediate thoughts that one of the key meta packages wasn’t there in the first place.
Wallstreet “no longer worked” - again, if the upgrader was having problem you might have been left with the old 25.10 version.
Personally, I wait and reinstall: I did that with 24.04, and I’m doing it again with 26.04, even though I’ll admit it has better graphics on my laptop.
In short, 26.04 isn’t my daily driver yet, even though I’ve tweaked it to work around the little glitches that were bothering me.
I had 26.04 installed on one of my machines and become infuriated one reboot after. Nothing worked the way I had configured it on 25.10. Plank was gone, my layouts and makeovers were gone, it took me about a day to restore part of my setup and laf. As a result I am still sticking with 25.10 on my main machine.
I really am frustrated and disappointed. I have been suggesting Ubuntu Budgie to many people, a considerable number of them now flooding me with complaints…
As a matter of fact I am thinking of choosing another distro now.
I have no stake in the company, but I responded differently by researching and publishing workarounds while waiting for things to settle down.
Still, we have to give credit where credit is due for the work that was done, even if the result surprises or confuses some people. :roll_eyes:
All,
thanks for the feedback
I can confirm that there is a serious issue if you have previously installed with the minimal install option. At the end of the process, when you are asked whether to keep or remove packages, if you press REMOVE, it will remove SDDM and leave you with a TTY.
If you press KEEP then all is ok.
For the moment I’ve revised the release notes - Ubuntu Budgie | Ubuntu Budgie 26.04 LTS Release Notes
The minimal install issue is a bug and should be reported to launchpad - I’m guessing initially against the update-manager - the triagers will advise further if that is the wrong package
Ubuntu devs have found what causes the issue of the TTY after the uplift (hopefully).
If you want to follow along this is the launchpad issue and the current proposal to resolve
I’m using 24.04… and sticking with it till end of life… then I’ll upgrade to 26.04. I did the same exact thing last time. Maybe it’s boring but at least its predictable… and no BUGS. Have also been experimenting with Linux Mint on an old Thinkpad… and have installed Plank together with Cine-Menu to create a somewhat similar look to Budgie, but its not the real deal. Is it an alternative option? Only if Ubuntu gets REALLY horrible and comes crashing down. :rofl:
I’ve just upgraded to 26.04. Issues have arisen.
[1] Every time I press the CAPS LOCK key, a REALLY ANNOYING popup covers the text I’m typing, which was never seen in 24.04. How do I get rid of it?
Google’s AI is useless here, as the “advice” it gives asks me to look for options that DON’T APPEAR in the relevant application menus, and I can’t find ANY documentation to help me work out how to get rid of the annoying popup.
[2] If I leave the machine without user input for any length of time, on 24.04, a mouse click or hitting the spacebar would display a login prompt asking for a password. On 26.04, no such indication occurs, and I’m left with a completely black screen. I only found out by pure accident, that I could still type the password in, but instead of seeing a dialogue box with a character count, so I can double check while typing, I see NOTHING. Will this be rectified?
[3] If, like me, you have a laptop with a luxurious maximum screen resolution, you have to discover the hard way how to change the resolution and pixels per inch setting, in order NOT to lose the budgie icon at the top. Surely a more friendly way of doing this could have been developed before release? Only working with a 2880x1800 screen after cataract surgery is NOT pleasant.
Please take a picture so that we can see what you are seeing.
You should be seeing a circular wheel for every character you are typing of your password.
The locker should be showing your desktop background wallpaper if everything is working. Suggest test this by changing your desktop wallpaper to a jpg image.
If you want a traditional password entry locker then install the gtklock package
So to manage displays you use wdisplays
Only here—especially for this kind of thing?
But at least that proves that (this) AI isn’t all that smart.
As for me, I trust my HI (Human Intelligence), even if it is a little limited. :flushed_face:
I don’t even see my wallpaper, which IS a JPG. Specifically, a photograph of a butterfly I shot in 2015.
Likewise it would have been nice to have been told about wdisplays in some documentation.
For your swaylock issues what is the output of
ps -ef | grep sway
Command output is as follows (raw, not formatted):
calilas+ 4248 1 0 Oct24 ? 00:00:00 swayidle -w timeout 30 dbus-send --type=method_call --dest=org.buddiesofbudgie.BudgieScreenlock /org/buddiesofbudgie/Screenlock org.buddiesofbudgie.BudgieScreenlock.Dim resume dbus-send --type=method_call --dest=org.buddiesofbudgie.BudgieScreenlock /org/buddiesofbudgie/Screenlock org.buddiesofbudgie.BudgieScreenlock.Undim timeout 300 wlopm --off * resume wlopm --on * timeout 300 swaylock -Fklf -c 000000 before-sleep swaylock -Fklf -c 000000 timeout 900 if dbus-send --print-reply=literal --dest=org.buddiesofbudgie.BudgieScreenlock /org/buddiesofbudgie/Screenlock org.buddiesofbudgie.BudgieScreenlock.OnBattery | grep “boolean true” > /dev/null; then dbus-send --system --print-reply --dest=org.freedesktop.login1 /org/freedesktop/login1 org.freedesktop.login1.Manager.Suspend boolean:false; fi
calilas+ 5113 4074 0 Oct24 ? 00:00:00 swaybg -i /run/user/1000/budgie_wallpaper_bordered.jpg --mode fill
calilas+ 172387 171399 0 19:37 pts/0 00:00:00 grep --color=auto sway
I can see that swaylock is deliberately setting the colour as black.
Looking at the code it thinks it cant find the wallpaper on gsettings. What is this value?
gsettings get org.gnome.desktop.screensaver picture-uri
Also what is this value?
gsettings get org.gnome.desktop.background picture-uri
Followup question. How are you changing wallpapers? I.e.what app are you using?
The gsettings questions are the right first step — if picture-uri returns an empty string or a stale path, swaylock will fall back to black rather than dimming a real image. I’d also check background picture-uri-dark, since newer Budgie versions may store the active wallpaper there and a script reading only the non-dark key could miss it. On the wallpaper-changing question, it would help to know whether the OP used the Budgie desktop settings panel or set it from a script, because the latter often writes the path differently and wouldn’t refresh whatever key swaylock reads.
Good point about picture-uri-dark. On my setup the panel and script routes definitely wrote the key differently, and I only caught it after comparing both values side by side. Emma, if you’re reading this thread too, it’s worth running the gsettings query for both the standard and dark keys before blaming swaylock itself. The background picture-uri-dark check that was mentioned is the one that saved me from chasing the wrong path entirely.
