I’m using nemo as my default file manager.
However, the button “open in terminal” does not open tilix, instead nothing happens when I click it. If I remember correctly, it did work on my laptop.
Is there a place where I set this up? Open in terminal works correctly in nautilus.
hey, thanks for your reply.
I’ve tried to set it via gsettings set org.cinnamon.desktop.default-applications.terminal exec 'tilix'
suggested here as well as
gsettings set org.gnome.desktop.default-applications.terminal exec tilix
But in both cases I get this message:
GLib-GIO-Message: Using the 'memory' GSettings backend. Your settings will not be saved or shared with other applications.
(process:5633): GLib-GIO-WARNING **: unknown schema extension 'd'
I’ve installed gnome-terminal and nemo opens that. so I’ll have to change the gsettings for org.cinnamon.desktop.default-applications.terminal somehow.
A quick Google for the memory message reveals a variety of possible causes. I don’t know what your setup is. For example do you have a different python installed from default? Do you have custom binaries that you have built?
This?
The tilix gsettings is definitely the way to go here.
Maybe you can use dconf-editor to edit that value manually
I got it, thanks! I’ve also came across something matplotlib related, but I thought that can’t be related.
The problem was that my anaconda env with python 3 was the first python in my path.
So here is the full solution:
make sure the default python is the first in your path
then run gsettings set org.cinnamon.desktop.default-applications.terminal exec tilix
After that it worked.
Btw the terminal shortcut ctrl + alt + t does often not work. Do you have any idea why?
