For 23.04, the currently built-in edge tiling will be replaced by Shuffler’s drag-snap. Read all about in the article here.
How is it possible to switch back to the old edge tiling? I used it frequently to maximize the windows, but with the new feature you would have to wait several seconds until the window gets maximized…
Several seconds? It is set to 0.6 sec. What are your specs?
Anyway, open Budgie Settings (NOT Budgie Desktop Settings) - > Edge tiling. You’ll be prompted to choose either built-in or dragsnap.
Okay maybe several seconds were a little bit exaggerated
It feels like around 1 sec.
Anyway, thanks for the quick reply!
