Problem to open app center
Hi! I just installed Ubuntu Budgie 25.10 on an HP Pavilion laptop and I think it’s fantastic. I have a problem, though: when I try to open the app center, it opens and then closes abruptly.
Before opening the app center, I switched to the Mojave visual environment and made other aesthetic changes, such as moving the buttons for each window to the left.
I’m thinking of reinstalling Ubuntu Budgie, but if you could help me solve this, that would be great.
Thanks in advance for your help.
if I remember correctly, app-center is called “snap-store” from a terminal.
So I would type snap-store in a terminal and see if there are any messages you can share.
Hi!
This is the result that appears on the terminal:
d@d-HP:~$ snap-store
Gtk-Message: 22:37:00.433: Failed to load module “xapp-gtk3-module”
Gtk-Message: 22:37:00.433: Failed to load module “appmenu-gtk-module”
Gtk-Message: 22:37:00.434: Not loading module “atk-bridge”: The functionality is provided by GTK natively. Please try to not load it.
(snap-store:10363): IBUS-WARNING **: 22:37:01.161: Failed to mkdir /home/d/snap/snap-store/1300/.config/ibus/bus: Not a directory
INFO snap-store: Logging to /home/d/snap/snap-store/1300/.local/share/snap-store/snap-store.log
Thanks for your help :folded_hands:
sudo apt-get install libxapp-gtk3-module appmenu-gtk3-module
The above is a logical next step according to the messages you have reported.
Thanks!
I ran sudo apt-get install libxapp-gtk3-module appmenu-gtk3-module and this is the result:
[sudo: authenticate] Password:
Leyendo lista de paquetes… Hecho
Creando árbol de dependencias… Hecho
Leyendo la información de estado… Hecho
libxapp-gtk3-module ya está en su versión más reciente (2.8.8-1).
fijado libxapp-gtk3-module como instalado manualmente.
appmenu-gtk3-module ya está en su versión más reciente (25.04-1).
fijado appmenu-gtk3-module como instalado manualmente.
Solving dependencies… Hecho
El paquete indicado a continuación se instaló de forma automática y ya no es necesario.
python3-pyudev
Utilice «sudo apt autoremove» para eliminarlo.
0 actualizados, 0 nuevos se instalarán, 0 para eliminar y 0 no actualizados.
The app center opens, but I can’t click on anything and I can’t close it from the desktop.
Thanks
Hi @roquestar,
Since “snap-store” is a snap, have you tried uninstalling and reinstalling it?
sudo snap remove snap-store
sudo snap install snap-store
Juste in case, log out and log back in between the two commands.
