I am having issues with Budgie 18.04.3 LTS and thought that I would just install and start from scratch but it seems that my OS has become sentient and is fighting my efforts. Here is what I have done:
I downloaded the package off of the website and made a bootable disk with ubuntu-budgie-18.04.3-desktop-amd64.iso using the Startup Disk Creator. When the computer was restarting, I hit F12 to go into the BIOS menu and selected “Removable Devices”. However, it then just restarts normally. It doesn’t bring up the dialog box and I am pretty sure that it is not reading out of the USB. I have tried this on all of the USB ports to the same effect.
I found a post saying that it has to be installed with a USB but I am not sure how to proceed if it won’t recognise my flash drive. Undaunted, I searched around and found instructions to reinstall from /home (I can’t find the page where I read this but I thought that it was somewhere in askubuntu.com). I moved the .iso file into the home folder and then went to tilex and entered:
sudo mkdir /media/cdrom
cd ~
sudo mount -o loop ubuntu-* /media/cdrom
It brings up a box showing the .iso file on the USB and in the home folder but I am really not sure what to do with this information. When I click on either, it just brings up a menu with all of the folders.
Can someone give me steps to just reinstall the OS entirely? I am not worried about preserving files or settings, I just want a clean slate. Thank you!
