I use Budgie as a fresh install on a Asus Zenbook laptop and have a rellay annoying issue with screen resolution.
With external hdmi screen, I configure ubuntu to only display on the big external screen (laptop screen off).
But each time I unplug the external screen, something goes wrong : the laptop display is unusable. Seems to be in really high resolution, I can see only a part of the of the screen and the mouse pointer does not point anything, it looks like it is at a wrong place.
Planck also is at a wrong place, sometimes in the middle of the screen and cannot be triggered…
If I try to suspent as this, then it never wake up again and I have to do a hard restart (hold power button down for 10 sec, and then restart the laptop).
Any idea of what can cause that? and a solution? I cannot restart my computer each time I want to plug or unplug an external screen.
Here is xrandr outpput:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 174mm
1920x1080 60.05 + 60.01 59.97 59.96 59.93 48.04*
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
