Hi, I use a pc toshiba satellite pro A200 with Ubuntu Budgie 20.04 LTS, I tryed to add an external monitor via VGA interface. When it boots the pc replies the screen in the external one until the login screen, after the login it doesn’t launch the desktop, the laptop monitor is black, no signal in the external monitor … Ubuntu seems to do somethings but nothing appears until I pullback the vga cable. Could anybody help me?
Thank You, Gianpiero.
PS I tryed with gnome it works, I can use both monitors in mirror or joined … It seems a problem with Budgie
Solved using FN+F5 to activate second screen! As suggest here
Now it works fine
Ciao Gianpero.
