I accidentally messed up Cairo-Dock. There’s an extra panel on the bottom left. The original is still there but no longer works. I was trying to add a clipboard but have no idea how do do it. As nice as Budgie looks it’s hard to use.
Do you have a screenshot? UB out of the box uses Plank not Cairo Dock.
Configuring plank is achieved via Menu - Plank Preferences. You can add a clipboard widget via plank through the Plank Preferences window.
Thanks. I figured out how to get rid of the extra panel. Is Plank different from Cairo Dock? And what actual clipboard manager would I install or use. Quick Note so far has been useless for copying text. It says it copies text that is being typed, but it isn’t copying this. But more over I need a clipboard that retains what I highlight and copy.
OK, I didn’t know that. I’ve never used either before. What about a good clipboard. I don’t care if it is on the top panel or in Plank I just need one that works.
Personally I use copyq - just search from Menu - Software. Use budgie-desktop-settings Autostart to add the application so it starts on next logon. It appears in your panel
Thanks I found “Clippy” and it works. Still confusing how to add and remove features. I don’t know if you are a developer of this, but it seems to me “Plank” should be in some area of the System Menu either under Preferences or Tools or Desktop Preferences. I don’t see it as an Accessory. Same with “Menu Editor” which really belongs in System Tools
I rarely navigate down the menu - just typing the first two or three chars in the search box and hitting return is enough to run stuff.
Thanks for your help. I would have to look for a screen shot app. Just getting started with this. I was using Kubuntu, but 19.10 is crashing constantly. Budgie so far has been stable. If I can learn to use it, and configure it I think I will like it.
Use Menu - Budgie Applets and install the screenshot applet. Logout and login and add the new applet via budgie-desktop-settings - panel - add applets.
I messed up by installing Cairo-Dock. Now there are broken packages. Don’t know how to fix it. Not good with the terminal but know a little apt-get. Is there a “repair” command?
Oh, OK. I’ll do it later today I have to get ready to go to tennis.
Depends on the error.
Run
What warnings/errors do you have?
It’s in synaptic and says “broken packages” so it won’t purge cairo-dock.
sure - run the two apt commands in a terminal and report the results.
Yes, “sudo apt update && sudo apt upgrade” helped, and then I ran "sudo apt autoremove cairo-dock" which I believe got rid of all the cairo dock components:
Removing cairo-dock-plug-ins (3.4.1-4build1) …
Removing cairo-dock-alsamixer-plug-in (3.4.1-4build1) …
Removing cairo-dock-animated-icons-plug-in (3.4.1-4build1) …
Removing cairo-dock-cairo-penguin-plug-in (3.4.1-4build1) …
Removing cairo-dock-clock-plug-in (3.4.1-4build1) …
Removing cairo-dock-core (3.4.1-3) …
Removing cairo-dock-dbus-plug-in (3.4.1-4build1) …
Removing cairo-dock-desklet-rendering-plug-in (3.4.1-4build1) …
Removing cairo-dock-dialog-rendering-plug-in (3.4.1-4build1) …
Removing cairo-dock-dnd2share-plug-in (3.4.1-4build1) …
Removing cairo-dock-drop-indicator-plug-in (3.4.1-4build1) …
Removing cairo-dock-dustbin-plug-in (3.4.1-4build1) …
Removing cairo-dock-folders-plug-in (3.4.1-4build1) …
Removing cairo-dock-gmenu-plug-in (3.4.1-4build1) …
Removing cairo-dock-icon-effect-plug-in (3.4.1-4build1) …
Removing cairo-dock-illusion-plug-in (3.4.1-4build1) …
Removing cairo-dock-impulse-plug-in (3.4.1-4build1) …
Removing cairo-dock-keyboard-indicator-plug-in (3.4.1-4build1) …
Removing cairo-dock-logout-plug-in (3.4.1-4build1) …
Removing cairo-dock-mail-plug-in (3.4.1-4build1) …
Removing cairo-dock-messaging-menu-plug-in (3.4.1-4build1) …
Removing cairo-dock-motion-blur-plug-in (3.4.1-4build1) …
Removing cairo-dock-musicplayer-plug-in (3.4.1-4build1) …
Removing cairo-dock-netspeed-plug-in (3.4.1-4build1) …
Removing cairo-dock-powermanager-plug-in (3.4.1-4build1) …
Removing cairo-dock-quick-browser-plug-in (3.4.1-4build1) …
Removing cairo-dock-recent-events-plug-in (3.4.1-4build1) …
Removing cairo-dock-remote-control-plug-in (3.4.1-4build1) …
Removing cairo-dock-rendering-plug-in (3.4.1-4build1) …
Removing cairo-dock-rssreader-plug-in (3.4.1-4build1) …
Removing cairo-dock-shortcuts-plug-in (3.4.1-4build1) …
Removing cairo-dock-showdesktop-plug-in (3.4.1-4build1) …
Removing cairo-dock-showmouse-plug-in (3.4.1-4build1) …
Removing cairo-dock-slider-plug-in (3.4.1-4build1) …
Removing cairo-dock-stack-plug-in (3.4.1-4build1) …
Removing cairo-dock-switcher-plug-in (3.4.1-4build1) …
Removing cairo-dock-system-monitor-plug-in (3.4.1-4build1) …
Removing cairo-dock-systray-plug-in (3.4.1-4build1) …
Removing cairo-dock-terminal-plug-in (3.4.1-4build1) …
Removing cairo-dock-tomboy-plug-in (3.4.1-4build1) …
Removing cairo-dock-toons-plug-in (3.4.1-4build1) …
Removing cairo-dock-weather-plug-in (3.4.1-4build1) …
Removing cairo-dock-wifi-plug-in (3.4.1-4build1) …
Removing cairo-dock-xgamma-plug-in (3.4.1-4build1) …
