Hi. Ive had major problems (seg errors and various) stopping several apps which were all working a couple of months ago, on my new Lenovo E590 Thinkpad notebook.
sudo lspci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (Whiskey Lake) (rev 02)
What helped me sort it was the following command: sudo lshw -C display
which showed the driver was xserver-xorg-video-intel which is not recommended; its older and problematic. Aptitude recommends use system default which is driver=i915).
After removing this errant driver, its solved my applications crashing problems and more.
Hope this helps someone else.
eg sudo apt-get remove xserver-xorg-video-intel
(make sure you note the above line in case reboot fails, then if fails, reinstall on command line: sudo apt-get install xserver-xorg-video-intel
