Hi, I installer the snap from the software application and the client was terribly slow. In another distro not natively using snap I had the client installed with the deb package and the app was much more responsive. Is this normal ? Could we have the choice when installing apps ? any fix ? thanks
Hi and welcome.
Snap issues should be raised here
You can install the deb version of spotify from their website
I note spotify also say install snaps as well so I am guessing they are responsible for their snap.
As to alternatives to snap and deb you can use flatpak from the software centre by installing the flatpak plugin … look at the welcome app - recommendations
