For some reason, no matter what is second in this list, the display changes to a qwerty keyboard. If i put greek, it turns to english, french turns to english too and even german like that second place is cursed by the english language. Is there any reason for that? how can i solve it?
I am using Win + Space to switch keyboard. It works well except the second keyboard is always english. For example in the order i showed you, if i switch once it will be english, and if i switch a second time it goes to greek like it’s supposed to, and then one more time and it’s back to german
The issue occurs with any keyboard layout that I put in second place. If I put german (which is my systmm language) in second place, it will put an english layout instead. THe french layout works well when it’s first or third, and same for greek, that’s why I said it feels like the 2nd place is cursed haha
I’ve tried your patch and it works perfectly for me so far. I tried the Chinese (WuBi-Jidian-86-JiShuag-6.0) keyboard and as you can see on the screenshot below it works perfectly fine too:
I had the same problem with spanish keyboard layout on second place. I just thought that spanish keyboard layout does not work at all. But testing it was the same behavior: on third place it worked fine. Your ppa-update worked well for me as well. Now it works on second place as well.
So many thanks and I hope it finds its way into one of the next ubuntu budgie updates for 22.04lts
All the best,
Olaf
