System Monitor Applet With Font Icons
So if you were wanting icons in the System Monitor Applet here is how I did that. Using Font Viewer choose the font with the icons you want to use then can copy and paste icon into the System Monitor Applet Preferences window and get the desired font to show. See screenshots below.
NOTE: Just make sure to install the font you will be using.
Panel Example Scrot:
Snapshot_2023-01-21_09-34-25
thx for sharing - ingenious!
Your most welcome and thank you! :slight_smile:
