Everyone,
Budgie Desktop v10.5.3 has been released by upstream. We have packaged this for 20.04/20.10 and 21.04 to enable everyone to help test it.
Lots of goodies to play with - this is described by Fashionable GNOME Forty | The Roundup #19 | Solus
If you are coming from 20.04/20.10 then the jump to v10.5.3 is much larger - the release of 10.5.2 is described here in the budgie-desktop section of our release notes Ubuntu Budgie 21.04 Release Notes | Ubuntu Budgie
To help test follow these instructions:
sudo add-apt-repository ppa:ubuntubudgie-dev/budgie-desktop-test
sudo apt dist-upgrade
sudo apt purge gnome-screensaver
Note - you will not be able to use budgie-hotcorners since this needs gnome-screensaver. We’ll have to fix this via our budgie-extras repo
Next reboot
If you are using 20.04 / 20.10:
If you haven’t already got dconf-editor then please install it and change the key value in com.solus-project.budgie-wm desktop-type-override to the value “nemo”
Logout and login
Let us know how you get on - good and not so good.
Early testing will help iron out issues before formal release.
Thanks.
