ThinLinc Remote Connection
Hi, someone has success with ThinLinc Remote Desktop?
I installed server version on Ubuntu Budgie 24.04. Its come without “budgie profile” and i have added into conf - calling “budgie-desktop”.
Can connect, but, disconnects after some seconds.
XDG session for Budgie is budgie-desktop?
Cant get good solution for remote desktop. x11vnc and xrdp are bad. NoMachine works sometimes.
Trying ThinLinc now, but… :sleepy:
Upgraded MESA stack solve some errors on ThinLinc logs, but…
Syslog:
2024-09-03T14:06:53.463468-03:00 bruno-VirtualBox systemd[1]: Started session-5.scope - Session 5 of User bruno.
2024-09-03T14:06:53.607327-03:00 bruno-VirtualBox systemd[1]: Started session-6.scope - Session 6 of User bruno.
2024-09-03T14:06:53.922554-03:00 bruno-VirtualBox systemd[1]: session-5.scope: Deactivated successfully.
2024-09-03T14:06:54.295345-03:00 bruno-VirtualBox systemd[1]: Started session-7.scope - Session 7 of User bruno.
2024-09-03T14:06:59.117608-03:00 bruno-VirtualBox budgie-session[3510]: budgie-session-check-accelerated: GL Helper exited with code 512
2024-09-03T14:06:59.161237-03:00 bruno-VirtualBox budgie-session[3530]: libEGL warning: DRI3: Screen seems not DRI3 capable
2024-09-03T14:06:59.161309-03:00 bruno-VirtualBox budgie-session[3530]: libEGL warning: DRI3: Screen seems not DRI3 capable
2024-09-03T14:06:59.172555-03:00 bruno-VirtualBox budgie-session[3530]: MESA: error: ZINK: failed to choose pdev
2024-09-03T14:06:59.173165-03:00 bruno-VirtualBox budgie-session[3530]: libEGL warning: egl: failed to create dri2 screen
2024-09-03T14:06:59.214372-03:00 bruno-VirtualBox budgie-session[3510]: budgie-session-check-accelerated: GLES Helper exited with code 512
2024-09-03T14:06:59.386820-03:00 bruno-VirtualBox systemd[1]: session-6.scope: Deactivated successfully.
2024-09-03T14:06:59.386901-03:00 bruno-VirtualBox systemd[1]: session-6.scope: Consumed 1.871s CPU time.
2024-09-03T14:07:01.047736-03:00 bruno-VirtualBox org.buddiesofbudgie.BudgiePanel.desktop[2689]: sys:1: Warning: instance with invalid (NULL) class pointer
2024-09-03T14:07:01.047821-03:00 bruno-VirtualBox org.buddiesofbudgie.BudgiePanel.desktop[2689]: sys:1: Warning: g_signal_handlers_disconnect_matched: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
2024-09-03T14:07:01.057509-03:00 bruno-VirtualBox systemd[1]: session-7.scope: Deactivated successfully.
How have you configured virtualbox? 3D acceleration with 128Mb graphics ram and the default vms graphics driver?
Yes.
128 MB
3D Graphics
Default VMSVGA
I want to try in Virtualbox before apply to my workstation.
**** Same results with 3D Graphics disabled
Basically you are battling with virtualbox graphics which can and is known to be very weird with graphical stuff. You will have better luck throwing a build on a spare laptop etc with a decent graphics card from the last 10 years.
