Ubuntu Budgie 18.04 issues
System tray can’t display the running app like steam, telegram…
Has anybody encontered this?
check to see if the appindicator applet is missing from your panel - usually those apps have tweaks that require the appindicator applet to be running.
I haven’t encountered this. Did you do an upgrade or clean install? Mine was an upgrade from 17.10.
Thank you. Problem solved !!!
