Love the latest 21.10 Beta Daily release build , but the Login Window Settings Software will not install a picture. Any advice or thoughts on this?
Thanks for your time.
Everything here is working fine on impish.
Do make sure the path to the picture you are using is accessible - avoid home folder locations since they are normally inaccessible via the login manager
…or just make sure the whole path to picture used in login screen is « readable » by anyone ( others ),
someting like rw-r–r-- for the final file and rwxr-xr-x for the folders throughout the path.
Since Ubuntu 21.04 the default rights in home folders are rwXr-X--- ( it was rwXr-Xr-X before ).
Or ( I did not test that but it should also work ) add the user lightdm to the group of your user.
