System:
Host: vivo Kernel: 5.13.0-35-generic x86_64 bits: 64
Desktop: Budgie 10.5.3 Distro: Ubuntu 21.10 (Impish Indri)
Machine:
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop M3401QC_M3401QC
v: 1.0 serial:
Mobo: ASUSTeK model: M3401QC v: 1.0 serial:
UEFI: American Megatrends LLC. v: M3401QC.303 date: 08/06/2021
Battery:
ID-1: BAT0 charge: 63.6 Wh (100.0%) condition: 63.6/63.0 Wh (100.9%)
volts: 12.0 min: 12.0
CPU:
Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed: 1197 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1197 2: 1198
3: 1198 4: 1197 5: 1397 6: 1397 7: 1197 8: 1197 9: 1198 10: 1197 11: 1197
12: 1197 13: 1197 14: 1197 15: 1198 16: 1197
Graphics:
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nvidia
v: 510.47.03
Device-2: AMD Cezanne driver: amdgpu v: kernel
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati,nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 2880x1800~90Hz
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.0-35-generic LLVM 12.0.1)
v: 4.6 Mesa 21.2.6
Audio:
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.13.0-35-generic running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.32 running: yes
Network:
Device-1: MEDIATEK driver: mt7921e
IF: wlp2s0 state: up mac: 48:e7:da:ba:95:49
Bluetooth:
Device-1: IMC Networks Wireless_Device type: USB driver: btusb
Report: hciconfig ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: no
address: 00:00:00:00:00:00
Drives:
Local Storage: total: 1.82 TiB used: 71.62 GiB (3.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNVS2000G size: 1.82 TiB
Partition:
ID-1: / size: 1.8 TiB used: 71.62 GiB (3.9%) fs: xfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 8.6 MiB (1.7%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: partition size: 15.83 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
Sensors:
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): cpu: 0
Info:
Processes: 394 Uptime: 6h 6m Memory: 15.04 GiB used: 3.46 GiB (23.0%)
Shell: Bash inxi: 3.3.06
Pros: excellent 2880*1800 OLED screen, Nvidia driver 510 works fine, Mediatek WiFi mt7921e recognised at live install (actually the only distro I know which handles this), excellent performance
Cons: no hibernation, wrong suspend function (dot key and brigthness seting is not working after return from susopend) bluetooth not working (at least I could not manage to installl a bluetooth mouse)
I appreciate any assistance and advice to manage cons - all in all this is an excellent laptop with unbelievable output.
If you have just installed on the laptop my advice would be to try the 22.04 daily. This comes with the 5.15 kernel which should behave much better on newer hardware such as yours.
Advice taken.
Boot time 22.04 daily 7 (seven) seconds.
System:
Host: vivo Kernel: 5.15.0-23-generic x86_64 bits: 64 Desktop: Budgie 10.6
Distro: Ubuntu 22.04 (Jammy Jellyfish)
Machine:
v: 1.0 serial:
Battery:
ID-1: BAT0 charge: 62.3 Wh (98.0%) condition: 63.6/63.0 Wh (100.9%)
CPU:
Info: 8-core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
Speed (MHz): avg: 1216 min/max: 1200/3200 cores: 1: 1197 2: 1197 3: 1195
4: 1197 5: 1197 6: 1195 7: 1197 8: 1196 9: 1196 10: 1196 11: 1397 12: 1395
13: 1197 14: 1197 15: 1196 16: 1121
Graphics:
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nvidia v: 510.54
Display: x11 server: X.Org v: 1.20.14 driver: X:
loaded: amdgpu,ati,nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: amdgpu resolution: 2880x1800~90Hz
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.0-23-generic LLVM 12.0.1)
v: 4.6 Mesa 21.3.5
Audio:
Sound Server-1: ALSA v: k5.15.0-23-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e
Bluetooth:
Report: hciconfig ID: hci0 state: up address: 48:E7:DA:BA:95:48 bt-v: 3.0
Drives:
Local Storage: total: 1.82 TiB used: 26 GiB (1.4%)
Partition:
ID-1: / size: 1.8 TiB used: 25.99 GiB (1.4%) fs: xfs dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
Swap:
dev: /dev/nvme0n1p3
Sensors:
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Info:
Processes: 440 Uptime: 1h 20m Memory: 15.04 GiB used: 2.88 GiB (19.1%)
Shell: Bash inxi: 3.3.13
Pros: excellent 2880*1800 OLED screen, Nvidia driver 510 works fine, Mediatek WiFi mt7921e recognised at live install (actually the only distro I know which handles this), excellent performance, bluetooth works, suspend works
Cons: hibernation needs some further care (got some ideas), wifey says ‘Hey du bist ein Jodltalent’.
Just for the record Asus Vivobook Pro 14 OLED (M3401Q) works well with Ubuntu Budgie 22.04. Bluetooth, touchpad, WiFi works from scratch, screen lock works after removal of gnome-shell-common package, suspend works, hibernation works after setting proper grub resume data. Numpad on touchpad and fingerprint reader on switch button is not working as there are no Linux drivers for them - at least no drivers that I know.
No drawbacks that I know at the moment. This is one of the the strongest laptop configurations on Linux at an affordable price. Thank you for developers of Budgie and the community.
How enable NumberPad
How enable FingerPrint
