Hello dear community,
within my Ubuntu Budgie installation, the ubuntu-budgie-welcome snap does not start anymore. It just quits with the following terminal message:
# The command to run comes from the freedesktop file provided
$ env BAMF_DESKTOP_FILE_HINT=/var/lib/snapd/desktop/applications/ubuntu-budgie-welcome_budgie-welcome.desktop /snap/bin/ubuntu-budgie-welcome.budgie-welcome %U
snap-confine has elevated permissions and is not confined but should be. Refusing to continue to avoid permission escalation attacks
What a pity! Without the Welcome App I don’t see any other way to manage Budgie applets? Or is there another way?
On the search for a solution I already tried the following from Ask Ubuntu:
$ sudo apt purge snapd snap-confine && sudo apt install -y snapd
But that didn’t help, at all. Any further suggestions are appreciated. Hopefully someone can help?
Thank in advance
All the best,
Markus
I can’t get both (guest session and snap) working at the same time
for snap works with and guest session works without AppArmor, only.
