Update 26.10 Problem with GUI loss
26.10 update to my Budgie trashed my GUI. How do I get it back?
Bruce
Hi @bruce-ott!
Try this tip David gave me about a similar problem.
If you no longer have access to your system, you can access the .config/dconf directory from a live session on an installation USB drive and rename the .config/dconf/user file to .config/dconf/user.bak or delete it.
Thanks for the quick reply
Bruce
