USB bluetooth adaptor fail to connect again after sleep
it’s a generic one, no USB driver needed to function.
Every I went into sleep mode and woke up the computer, this bluetooth adapter simply disappeared.
I have to unplug and plug it in again after wake up from sleep in order for budgie to recognize it again.
I checked the bluetooth always on box in power management setting.
Please help, thank you.
what version of UB are you running?
What kernel are you running? uname -a
If you have tlp installed - does uninstalling it, rebooting and then suspending/resuming work?
sorry for my late reply. I just came back from a business trip.
yes, have tlp installed, I will try to uninstall it and try again
thanks
