When I minimize a screen it simply disappears. Should it not be visible where it can be recalled?
mc
mc
By screen you mean window? If so, clicking its icon does not work? Which application?
It does not seem to matter whether I’m working in LibreOffice or Chrome, when I minimize a screen it simply flies off screen leaving no indication what I might click to retrieve it. I have to always start over.
mc
Please activate window previews, then when pressing alt-tab, can you activate the window? Also: multimonitor or single?
mc
Yeah, you wrote that, but please see my previous message.
That tip about Alt-Tab solves the problem. I was not aware of that move. Thank you.
mc
What is your UB version?
Problem solved and I thank you.
mc
